CPS1 Kick Pins
J69
281CR
I've been looking for a SF2HF board for a few months now to no avail. I decided to get one off Yaton through ebay as it was reasonably priced, supposedly fully working and, worst case, if it turns up broken I can appeal through ebay and likely get a refund.
However, whilst waiting for it to cross the ocean I took a closer look at the photos and spotted this
Those kick harness pins are f***ed!
I'm hoping its just a case of straightening them out, but if they are beyond saving what's the next step? Can the whole block of pins be removed and a new one soldered in its place?
lix
546CR
I find Yaton usually posts a good amount of pictures with everything they sell, sometimes even specifically taking pictures of repair or damage to the boards. Always have a good look and base your purchase on them, that's what I do.
Those pins should be the same as used on Sega Model 1/2/3 boards, search for JST NH, they're usually fairly robust due to their thickness so some gentle prodding with a screwdriver should put them back in their place. I've done it many a time.
TheDaddy
14 (93%)
7,230CR
Just wants bending back into place mate , Done loads of these and they will be good. Very very rare they snap.
Hope this helps,
Dave.
Del Griffith
17 (100%)
844CR
It’s the middle connector you’ll need to use (the most bent looking one!) It’s hard to tell if 2 of the pins are broken or perfectly straight.
Options
1.If no pins are snapped bend them back (as mentioned they are pretty tough, capable of ripping your finger nail off)
2.Swap with the one next to it if those are intact
3.Kick off it’s not fit for purpose if both have snapped pins
Finding a replacement connector shouldn’t be to difficult.
Seen you been after this board for a while, They getting harder to find then without taking a mortgage out!
