CPS1 Us Navy sync problem.
thechop
Model 3 Man
15 (94%)
388CR
Got a US navy CPS1 board that seems to not want to sync, all tests show ok on boot and game and sound run fine but it just won’t settle and rolls slowly and if I do manage to get it still it still has horizontal lines flash up and almost see the raster lines too.
Anyone familiar with these boards ? I know the A boards are somewhat flaky these days but have read it may be a 74ls08 directly under the C board.
Any help would be greatly appreciated.
Pete.
thechop
Model 3 Man
15 (94%)
388CR
Read this on the arcadeotaku wiki, may be relevant ?
Tip: Troubleshooting Sync Problems
If the CPS1 board works, but has no sync then this will apply. This will not apply if the game is not otherwise working OK.
The sync pulses are generated by the custom chip on the C board. Pins 118 and 116 on the C board carry the signal to pins 13 and 12 of the 74LS08 on the B board, directly under the C board. This chip ANDs the signals and the output pin, pin 11, connects to resistor R28 (on the smaller SMT style A board), then on to the sync pin of the JAMMA connector.
If the board is missing sync, first check for damage on R28 (220 ohm) and continuity to pin 11 of the 74LS08 on the B board. If those are good then check for pulses on pins 116 and 118 of the C board. If the pulses are there on BOTH pins and missing from pin 11 of the 74LS08, then replace the 74LS08. If one or more pulses are missing and the pins stuck low on 116/118 of the C board then reflow the custom chip on the C board. If that fails to fix the sync problem then replace the faulty C board
