aussiekanga
- Credits
- 69CR
Seeing i had some luck with Pacmania thought i would revisit this A board
i got this off a friend of mine, he said just showed a black screen somtimes garbage with a known good B board fitted.
When i got it i went over it with microscope couldn't find any issues with lifted pins or trackrot/damage, tried a known good working B board (ssf2) and yes he was correct either black screen or somtimes garbage, so i tried the test rom I got it to boot up just fine but it shows Sound INT and Q Sound as error hmm
Did a few basic stuff first with swapping over z80 (jumper set correctly) with a known working one, checking clock reset also changed both PALs and the 6264 ram but still showed both bad. Original ram tested Ok out of circuit
Put the scope on INT of cpu and i can see it as i reboot the pcb poll a interupt signal, so at this point i was thinking what else could it be
Ended up changing out the DL-1425 Q sound CPU from a damaged A board crossing fingers but sadly still errors
So i put it away until today so has anyone know what would cause this type of fault? The only thing i can think of is does the A01 talk to the z80. Thats all i can think of being maybe my issue seeing it just doesnt boot with a good B board fitted
