CPS2 Kick Harness / Jamma Help
susnet
8CR
Hey guys,
I'm still trying to work out and understand how my machine is wired up, I showed a picture the other week and it was suggested I needed JNX CPS2 adapter which I've now got.
Unfortunately the adapter hasn't just worked perfectly and now I'm learning and discovering some weird things.
It seems that there are 4 buttons wired to my Jamma harness, I thought the 4th button was only for Neo Geo? Anyways, the 4 buttons do work when testing in the Pandora's box.
When my CPS2 kick harness is plugged in on player 1 I get 5 working buttons, 1 button just doesn't work regardless, could just be dodgy wiring.
On Player 2 all 6 buttons do something, but 2 of the buttons are being used for the same 4th button if that makes sense? And none of the buttons are used for 6th button. Which I'm assuming means the 4th button is wired to the Jamma and the 6th button is mixed up somewhere in the wiring and is connected to the 4th button pin on the kick harness?
What makes it confusing for me and hard to work out is that the wiring is hard to follow, wires go into chop blocks, then sections wrapped up in electric tape and the wires come out different colours. Obviously with a bit of a headache I could unwrap bits and work out where each wire goes.
I know the guy I bought this machine from was running some non Jamma games with adapters, would he have had it wired up differently for certain games?
Should I disconnect the 4th button from the Jamma Harness and make sure it's wired to the kick harness? I'm also considering buying a new kick harness with all nicely crimped wires and just connecting it up to the buttons myself.
I'm still tempted to buy a new Jamma harness and wire the whole thing up myself, then I would learn it and know exactly how my machine works.
Here's the original picture:
And here's a new picture showing the JNX adapter, the chop block and dodgy wiring:
susnet2019-05-30 05:53:23
Titchgamer
123CR
The best solution would be a re-wire.
But if you dont want any further expense you need to start cutting ties and un-wrapping tape to trace the wires.
Sbdesign
SEGA collector
16 (100%)
1,726CR
So I take it you have 6 buttons on the cab?
The bottom 3 per a player (6 buttons) have blue wires connected - correct?
These all go to the cps adapter?
do the other buttons (look at wire colours or follow the cables) go to the top 3 buttons per player?
So is your jamma wired like this...
"On Player 2 all 6 buttons do something, but 2 of the buttons are being used for the same 4th button if that makes sense? And none of the buttons are used for 6th button. Which I'm assuming means the 4th button is wired to the Jamma and the 6th button is mixed up somewhere in the wiring and is connected to the 4th button pin on the kick harness?"
Button 4 of kick harness is probable also wired to the jamma edge for neo - so have a look at those wires.
On your picture looks like grey/blue wire and white wire are on pin 25 and pin c (NOT C) on diagram above.
I'd disconnect them. Desolder or cut (and use a choc if you need to join them again) or better, try following them, and are they splitting off from the cps connector?
My understanding is that then your wiring will be same as jamma, and with your adapter it will convert it to be wired like the first picture I posted.
Also to test, what happens if you do not use your adapter, from my guess - you would have 4 buttons on the pandora box.
Sbdesign2019-05-30 10:01:47
Flinnster
The Dino King
29 (100%)
2,566CR
The old 'CHAMMA' vs 'JAMMA' confusion returns. Sadly with an old jamma cab you have no idea what a previous owner or operator will have done with the wiring to suit their own purposes.... until you get in there and test it all.
CHAMMA / Chinese Jamma is simply the penultimate ground pin removed from 'Jamma' wiring and all 6 buttons for each player added to the remaining pins after button 3 on each side. That's it.
All my cabs are now CHAMMA wired. Means I can put all game pcbs, pandoras boxes, and Neo Geo MVS / PGM systems in straight away with no issues*
*The only issue is where Capcom & Namco games had specific 'kick' harnesses to connectors on their pcbs. For these I have an adaptor permanently on the pcb itself that runs a short set of wires from the kick connector on the PCB to the adaptor.. to make them Chamma. This means I don't have to fiddle with kick harnesses or disconnecting buttons etc..
I would advise you get a multimeter first, and beep continuity test each pin to each button.
I'm not sure how the JNX adaptor handles the GND on pins 27/e, but on a standard Jamma cabinet that uses both end pins for GND there, you'd see the effect of 'button 6' for both players being permanently on with a pandora's box.
Also I'm not sure if the JNX adaptor has any jumpers to swap buttons round or override certain input lines. This may explain the oddities you are getting on button 4 etc..
Finally.. if you do buy a new 'Jamma 6 button harness / loom'.. it'll be CHAMMA wired with 1 ground pin at the far end, not 2.
Flinnster2019-05-30 13:16:04
