CPS2 sound
Stox58
25CR
Hi all,
I’ve just picked up my first CPS2 board, it’s a Asia Phoenix Progear with no suicide battery. Every works ok but I have to keep turning the sound up with the button on first boot, which isn’t great for having it inside a cabinet. Is there a way in the menu’s to change the default?, or is this not possible due to the removal off the battery.
Thanks from Luke
r-type
633CR
Don't think so unfortunately. I have the opposite on my multi. Some games are far too loud and it's a pain to have to move the cab to turn them down. Others are fine though. Changing the coin setting was that annoying I had to wire a test button within reach of the coin door.
Asure
133CR
Volume settings are stored on board and should be kept even when you power it off and on again.
If it sticks at low, you might have a problem on the a-board (mother).
