Cps3 repairing
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
I have an issue with this chip.. mainly been I can't find a replacement. Not the one I'm pointing to. The one to the right. Above the 3383.
All the others say cu383 69k AF96
But the bottom one says CU383 62k ARCC.
It seemed to be the source of my colour issues and now the corner has fallen off so I've taken it off the board.
I've found some damage to the board I've now fixed but presume this chip will be dead now?
Is it worth trying it again or can anyone point me to a replacement
pulstar
41 (100%)
459CR
I would assume the 62K ARCC would be some kind of date code and not make the IC any different to the ones above. Something like this would be the replacement, but I would measure the original part and confirm this the replacement is the same width as I've had some SMD parts that were wrong because the package was marked wrong in listings on ebay.
Edit: A little too late
pulstar2017-06-11 20:36:28
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Yeah it matters as it's the physical size of the chip and pitch of the pins, you don't want one that's too big or too small.
Mouser seems to have all types but £12 postage?!
pulstar
41 (100%)
459CR
It looks like a SOIC package to me, definitely seems too big to TSSOP from the photos. The problem you have when it comes to certain SMD logic ICs is that you can have different widths in the same package. The easiest way to check is measure the width from pin edge to pin edge. Should be around 7.5mm for the SOIC package.
To be honest, SMD packages are a minefield because there are lots of variations within packages.
pulstar2017-06-11 21:28:17
pulstar
41 (100%)
459CR
JohnnyChaos
325CR
thanks a lot for helping dude. looking at that part on Mouser (SN74CBT3383DBQR) it lists it at 8.7mm long.
SN74CBTLV3383PWR TSSOP-24 is 7.8mm long which sounds more like it size wise. but I'm confused now if that could be the right part.
pulstar
41 (100%)
459CR
Right, so the part I found seems to be the wrong size. Did you measure the width from pin to pin? Does that make it around 4.40mm? If so, then TSSOP is the correct package like Ace surmised some posts up.
pulstar
41 (100%)
459CR
So, yeah, seems it is a TSSOP one you need, because I'm sure with SMD components you measure from pin edge to pin edge to get the width. Worth confirming that though.
Muppz
362CR
Yes it sounds like a TSSOP, manufacturers usually quote dimensions as
  • length from end to end of package
  • width of package material (body)
  • span of the pins across the chip (toe to toe)
You might find the information on these pages informative
http://www.ti.com/lsds/ti/packaging/packaging_tools/find_packages.page
It shows images of the types of package. Follow small outline (SO) in your case and you can view the Jedec standard packages.
Muppz
edit: clicky link
Muppz2017-06-15 21:06:40
JohnnyChaos
325CR
OK thanks a lot. looks like Mouser is my best bet. I'm going to have a look around the site over the weekend and see if there's anything else I might need before ordering
JohnnyChaos
325CR
so it was the TSSOP. thanks everyone
74CBT3383PWR
ordered and fit two and the board is alive again. unfortunately my colours are still messed up, they aren't as bad as they were. I do have some red, where as I didn't have any before. everything plays fine so I may leave it for now until a board comes up for sale.
