Cracked insulator plastic HOT?
Mame4All
41CR
When I was taking my HOT out my chassis to check it for short I noticed the insulator pad that goes between it and the heat shield was cracked I thought nothing of it at the time as I thought it was just pressed against the heat shield for cooling so I powered it up and there's loads of sparks coming from the HOT. Is this just due to the crack and nothing to worry about?
If so I'll just cut a thin piece of Plexiglass / perspex for replacment.Mame4All2014-08-27 11:52:39
4,964CR
you need to replace it
It should insulate from the metal but still work as heatsink for the HOT, if your monitor isn't working that won't help at all
