Crazy Balloon hardware?
virtvic
The Cabaret King
21 (96%)
2,012CR
I thought crazy balloon ran on identical hardware to space invaders, but system 16 says it uses Taito Safari hardware (as does Space Firebird)
I normally trust system 16, but because of the recent Aberdenn clearout, where there were a lot of Invaders boardsets running different games, I'm sure I saw some crazy balloon sets???
jonhughes
1,156CR
I've got an original PCB that I bought as fully working from Europe. I made a 'basic' harness for it a while ago and tested the PCB which proceeded to undergo a continuous boot cycle. I'm on holiday at the moment but can post pictures if you want them when I return some time after Monday.
Experience of these early Taitio boards would incline me to think that there is some kind of reset line or coin counter connection. Moon Cresta was no different but I could be wrong. Information on the board is scarce but there are schematics on line with the pinout. I have since converted the harness for the Moon Cresta boards but I may return to it soon.
Let me know if you need those pics.
5,653CR
It's not Taito Safari hardware. Safari was '77 and black and white.
It's a two board stack. Space Invaders is three - it's more capable hardware too.
Macro
2,010CR
not as far as I know, but it should be reasonably easy to change the code to not require it.
MAME does not emulate it correctly, one day I really need to find out what the correct numbers output are ..... (preferably before my one dies!)
jonhughes
1,156CR
Now that might explain the issue with mine. Do you know which chip it is please? I may just take a closer look at it and make sure everything is making contact with it.
Shafted once more, bought as working but if the protection can be by passed that would be one saved. Providing that is its only issue.
Macro
2,010CR
from the schematics I would guess 3E - PC3092
also looks like it handles coins and reset, so maybe not just a software patch, may need a few wires.
jonhughes
1,156CR
I may have spoken too soon on my PCB. The harness I had made was 'basic'. For one I didn't have the reset line attached to anything or any of the coin counters. This could be a similar case to what my Taito Moon Cresta was doing to me with power reset line not being connected.
Marco, do you know what the reset line is connected to please? It was ground on Moon Cresta. Are the coin counters attached also? Not sure where I would run those to. It may be that my harness was not 'complete' enough for the liking of the PCB to boot.
I'll make a new harness at some point and see what difference having things fully wired makes. I'll need to do that anyway to investigate the protection chip and see where that is at.
