Crazy kong graphics problem
Lurch666
4,518CR
So I'm trying to fix a crazy kong boot.
It follows the falcon schematic and the game is working but the graphics keep getting worse the more I work on it.
I wish I had taken pictures but figured I would fix this one pretty easy but it's kicking my butt.
So at first there was no text and the graphics were garbled.
I could make out some of the girders on the 1st screen,kong and the oil drum were in place but mario was a mess.
Replaced an LS157 at 11E and got text back albeit still scattered around the screen.
Kong,mario and oil were now correct but the rest of the graphics were still messed up.
Looking around the board using my slice I couldn't find anything more wrong and then the graphics got worse. The sprites were still OK but the entire screen was filled with the tiny mario used to indicate spare lives. I did notice that if I removed the CPU so the game wasn't running the screen was filled with the usual garbage with random characters and blank spaces but when the game was working I was getting a screen full of the same mario character so something was filling the background with the same data. If I played the game the sprites would work fine but obviously without the girders mario and the barrels would just fall down off the bottom of the screen.
last night while testing and finding nothing wrong again the screen suddenly changed to random garbage with black areas but now the sprites were in the wrong place.
Kong has turned white and is in the wrong place (he should be top right not bottom left) plus the barrels and mario are missing (probably offscreen).
The game still plays though.
Checked all eproms replaced all ram except the CPU ram.
Most LS157 checked and the chips buffering the address and data coming from the CPU.
I need to understand how the text and background graphics are stored and placed onto the screen.
Does anyone know which ram is used for text and background (girders platforms etc) storage?
7,230CR
Ram was my first though but you done that - I suppose its got to be one of the TTL's in the graphics addressing circuit possibly. Only fixed one of these and was ram on mine.
Lurch666
4,518CR
philmurr said:
What are you seeing on pin 24 of the Z80?
I'm getting a brief burst of activity on powerup then nothing while it's on the 1st screen (the one with text about coins and credits but obviously I don't see that on my board) then activity when it goes into demo mode but again all i see is the white kong and random graphics.
If I start a game then it's constantly active.
Forgot to mention I have a working falcon crazy kong to test against but wanted to narrow down where I'm looking.
I don't know weather to start at the CPU and work towards the video section or start with the timing 161s of the video section.
Lurch666
4,518CR
Now mostly solved.
Decided to start again since some of the chips that had checked good before might have failed and found pin 7 of the 157 at 9F was stuck high so the 2114s at 10J and 10H were not getting data.
Changed that and got more graphics but it was still a mess.
Since this 157 had checked good before I went to check the 157 at 6K that provided the select for the 2114s at 6F and 6H and pin 12 was again stuck high. The reason I might have missed this one is because it's only accessed when the screen is drawn so most of the time slice sees it as OK and can only see that pin 12 is giving the wrong output at certain times.
Replacing that one has restored most of the graphics. kong is still a mess and some sound are missing but mario,barrels and most the background are fine.
There are small bits of background that are corrupt so maybe one of the 2114s I used it not quite good.
I'm wondering if I used a bad 2114 when trying to fix this and it messed up the 157s somehow since it's a bit of a coincidence that both the 157s that handle chip select were bad.
Lurch666
4,518CR
Dammit.
Looks like my master plan has gone awry.
Got this boardset because I wanted a crazy climber but couldn't find a cheap one.
Figured since crazy kongs are just converted crazy climbers I could just do a rom swap.
Looks like a no go. Put in the ccboot CPU roms and just getting garbage. Game definitely isn't running.
Guess there's some missing hardware that got removed because it wasn't needed for kong.
Looks like I got two kongs now......
Lurch666
4,518CR
Fixed the sound today. Was getting tunes but no samples (walking,jumping etc).
Turned out to be another bad 157 at 4T this time.
just a few graphical glitches to fix now. Thinking maybe should just replace all the remaining 157s as all the problems were down to faulty ones on this boardset.
