Crazy Taxi Accelerator
Shedcade
4CR
Hi all, hoping i can get some help with my Naomi Universal Crazy Taxi
I've an issue with the accelerator, it's not responding (but the brake is fine).
If I go in to the game test and check the 'volumes' for this, the accelerator does not respond, however the accelerator setting does respond to the steering wheel being rotated...
Have I mistakenly set the wheel to act as steering and accelerator or has something died in the pedals?
I've been trying to solve audio issues so i have connected/disconnected things to get access (as well as fiddling in the test controls).
All help appreciated
Shedcade2019-06-19 15:48:47
5,415CR
Only thing in pedals is 5k pot, if steering pot is working accelerator it must be connected wrong
Need to check the connectors, i would say near the i/o pcb or more to that end as its only way they could get mixed up
Shedcade
4CR
Thanks Bods, i cant see anything connected incorrectly up near the i/o, i wonder if I've managed to short the i/o pcb or the accelerator pedal itself?
Fantazia2
2,246CR
Pretty sure if its the upright the pedal wiring ends up in the control panel as blue and a black 3 way connector, the steering should plug into the multi connectors you see when you lower the steering panel section.
Is it an original cart, have you checked what the cabinet type is set to, not sure if its set to deluxe if the wiring is different.
5,415CR
Not sure if it's same on all machines with analogue pot's but after recently wiring them up on Star Wars and USB interface, the pots on both these just have 5V one end, ground the other end and the middle pin the wiper inside that moves is the output to gameboard so it alters 0-5v out to game
That's how the USB one is, then when I looked up how the Star Wars is wired it was exactly same, which I didn't know, assuming then all arcade machines operate the same but not positive on that
Sure the steering was controlling the Accel input and not just looked wrong?
If you have a meter you could check the 5v on Pot and see what it has coming out if Sega ones work same, pots do wear, sometimes tracks inside wear out, of connection at the ends break or get cut through, so could be faulty pot. You can put a multimeter across the 2 end pins and you should get 5000ohms/5k or near to it, one on end and one on middle and when turning will see it alter the ohms reading
If you can get some pics of the pedal inside etc it may help
5,415CR
corn said:
Guess you could swap the brake and accelerator connectors to rule out the pot?
Can't remember what the pedals are like on Upright now, but the sitdown cabs have 2 3 pin connectors one to each pedal if I remember right, so yeah you could try swapping connectors over if the same on those cabs, don't have to mess about that way
corn
26 (100%)
231CR
Shedcade said:
Thanks Corn, is that the connection under the pedal plate, didn’t expect them to be interchangeable
You might be able to swap them there, but it might be a faff. If you trace the cables, I think they run through the flexi tube under the base and into the bottom of the cab near the motherboard. I think there are connectors there you can swap (3 pin ones).
Otherwise, take the bezel off and you'll see two 3 pin connectors that come out of the side leg. Just checked - mine are blue and black. you could swap them over there - probably the easiest.
I'm surprised the steering and pedals are mixed - the steering connects into the panel mounted connectors behind the dash and then into the analogue on the I/O. Hard to mix these with the pedals.
Shedcade
4CR
That’s great, thank you!
I’ll take the bezel off tomorrow evening and have a look at swapping the brake and accelerator over.
I’m wondering if the steering wheel acting as accelerator (as well as steering) is a red herring, perhaps filling in for the void left by the accelerator...
Vamino
Insert coin(s)
2,700CR
I'd also check the integrity of the cabling as well, I had a short on the accel cable on my Naomi driver which was causing all sorts of issues. The cables on the seat section had got crushed somehow.
Shedcade
4CR
I've swapped them over, the brake now works as the accelerator, does this lean it towards being an issue with the pedal?
5,415CR
So brake worked ok as brake and also works fine as accelerator, which means the wiring to i/0 is fine only leaves wiring from the pot on accelerator pedal to that connector or pot itself
So take pedal out and inspect connections and pot
