Crazy taxi gear problems
JackBurton
4CR
Have a bit of a strange problem on my crazy taxi.
Had a few friends playing it the weekend and when I went on for a game it started in reverse. Went to change it to forward drive and wouldn't stay in that gear, when I held up the stick into that gear it would go forward but not pick up any speed, once I let go it went back into reverse then.
Checked all the connections etc and seem to be grand. Ran test mode and all its saying is that game is in reverse gear.
Gear stick itself is fine physically, switchers not jammed or anything.
I replace the 2 micro switches on the shifter and I thought it worked but still the same issue
Have a wanted as up for a new IO board because I suspect that might be the problem but wondering what everyone else thought too
2,272CR
Io board would have been my first thought. Seen that happen a lot recently, usually you end up with a couple of digital inputs stuck on. Easy way to know for sure is unplug everything from the io except the power & USB and see if they still show as on.
Fantazia2
2,246CR
Open the control panel and trace the wiring for the shifter and unplug it from the bulkhead, the check in the controls test and if its still in reverse then its an I/O problem.
JackBurton
4CR
Yep all plugged out and still showing as on. So just find a new io board then I suppose
robotech
823CR
I have had a few sega naomi i/o boards with stuck inputs
So quite common i guess
All Still in the repair pile with the model 2 stuff for when i get my gaming mojo back
