Creating Havoc
Syrup2407
163CR
Thanks for the tech doc, will have a look later. Looks like you have most of the Atari vectors in the collection, not many missing from the line up, all look to be in great nick!
Syrup2407
163CR
Hi all,
It has been a long time since the last update on this project but lots has been happening and parts are arriving all the time.
I have decided I am going to go all out and build a dedicated cabinet for the repro board I built last year. All the externals (cabinet, CP, marquee, harness etc.) will be repro parts. The internals have had to be sourced from parts for sale on ebay and from other collectors KLOV / UKVAC etc.
The hardest part to source so far has been the monitor and I was lucky to be able to find a WG6100 that needed to be repaired, looking at the screen there is zero burn. I have stripped out, cleaned and repaired the HV board (cleaned, Cap kit, Zeners, Diodes new LOPT). The deflection board has been fitted with an LV6100 board along with a cap kit and replaced a number of the transistors. I just need to get a couple more components and can then test the monitor in my Black Widow cab.
Rebuilt Deflection board.
Rebuilt HV board.
I have also managed to source a Colour Vector Atari Power Brick and have rebuilt this with a repro panel from Takeman on KLOV and a new Big Blue.
Rebuilt Power Brick.
I have also sourced an ARII board and given this a full service, new caps, regulator etc.
Rebuilt ARII
I have also acquired a set of metalwork for the cabinet, the marquee and the CPO. I already had the roller controller.
As I have zero woodworking talent I am looking to source a repro cabinet from the states as the ones I have seen on there look to be of extremely good quality.
I also have a harness on order for the cab.
The £££££'s keep stacking up on this but I am in so deep I need to see this through to completion. As this will be a minty fresh cabinet I am hoping I can get this past the missius and into one of the rooms in the house rather than have it living in the garage with the rest of the cabs.
I am still working on the interface PCB to correct the bowing of the vectors on the WG6100 monitor, will update when I get the boards in my grubby mits,
Cheers,
Gav
bonehead
I'll get pix tonight
50 (100%)
1,729CR
That’s amazing work Gavin. If you need to borrow my conversion pcb/filter board let me know and you can borrow it for a bit.
Keep up the good work.
Steve
Syrup2407
163CR
Cheers Steve,
Might take you up on borrowing the conversion PCB as I want to check the dimensions before I send out the PCB files for manufacture.
Cheers,
Gav
Syrup2407
163CR
yep that's me, thanks for the tip!
I managed to get hold of Markrl and it looks like he will be making the MH cabs soon so I am hoping to get one of these!
Once I have the cab I just need to sort out the following:
Cabinet side art
Up / down door
Tempered glass (found a place in the states but its £200 incl the shipping (+customs on top)
Cardboard Bezel
Cabinet feet
Power cord
A few other bits and bons
Once this cab is done its onto a Quantum! (have the blank PCB so far!)
Cheers,
Gav
Syrup2407
163CR
Hi Steve,
Craig @ Giz10p has actually helped me out with a number of the parts to get this far!
Equites (PM incoming), I have found some plans at Classicarcadecabinets.com but apparently these are not 100% correct (some issues with the angles on the back of the cab). Do you have a different set of plans to these?
Also I have no wood work skills at all so am going to need a cabinet maker to help me on this, can you recommend any UK suppliers?
Cheers,
Gav
Syrup2407
163CR
Hi all,
After receiving the repro cab from the US last week I now have an (almost) complete Major Havoc.
It has taken a while to get all the bits together for this but I am super happy with how this has turned out. I just need to address the pincushioning of the WG6100 and will mock up a breadboard with the necessary circuit to see how it performs before I stick it on a PCB.
Cheers,
Gav
bonehead
50 (100%)
1,729CR
Wow that looks super cool Gavin.
Ok must be well pleased?
Roll on the vector games.
Does the adaptor pcb I have in mine sort the pincushion?if so you can borrow it and see if your able to copy the design.
Syrup2407
163CR
Hi Steve,
Good to hear from you. Yep I am really happy with how it has turned out, had kittens putting on the sideart as it all needed to be trimmed to fit (only one teeny bubble!).
Originally I was going to put the repro MH PCB into my Black Widow and I this would have needed the same conversion board as you have. As I have now put this into a dedicated cab with a dedicated harness then the conversion board you have wont work completely (as it is tracked for the wiring of the donor cab) (but thanks for the offer). I have the circuit information I need for the conversion but will need to make a board that did not originally (as far as I know) exist.
I have a quantum PCB to build next but no cab to put it in (or a monitor for that matter) after the expense of the MH my wallet wont handle another scratch build. I still have the control panel I was going to use to put MH into the black widow so that might get used on the Quantum.
Have you seen that there is going to be a software update to MH with new levels, bug fixes etc???
Cheers,
Gav
