CRT intererence
minwah
238CR
Anyone know of a material I can buy to shield EMI from a CRT?
If I put two of my cabinets close to each other the monitor chassis of one seems to interfere with the other monitor, causing 'wavy' video.
I'm sure this must have been covered but couldn't find an answer, so apologies if it is a common question.
obcd
3,830CR
It's probably not EMI. It's the magnetic field from one monitor interfering with the other. Try to hold an iron plate between the 2 monitors. It should shield the magnetic fields from each other. A TL ballast in close range can cause such interference as well.
minwah
238CR
Many thanks for your reply - I will see if I can find a sheet of iron.
How did commercial cabinets deal with this? They are usually positioned close together.
obcd
3,830CR
magnetic radiation fades away rather fast. If you place them 10 inches separated there shouldn't be much interference anymore. (If what I am assuming is correct.)
