CRT regenerator
porchy
994CR
I've got a couple.
One is a b&k precision 490. not the updated one though, it looks exactly like the 467 and uses the same adapter.
My other is a muted BMR 95 which is super easy to use once you read the manual a few times.
I've different adapters for each but I prefer the muted.
Many people swear by b&k precision 467 though
andrewsm
485CR
Not heard of this for years so thought I would add my knowledge on subject. Maybe Im slightly wrong here but here goes.
CRT regeneration was done years ago with old TVS (B/W) mainly and helped preserve the life of a tube as they were a fortune to replace and TVS were a fortune as well then.
Over prolonged use, the tube heaters will lose their abilty to generate electrons as the coating wears off gradually and with higher EHT (colour) they went quicker. This results is a dimmer display and usually focus and convergence issues.
To regenerate the tube, the heaters are run at a higher voltage than normal for a short period of time while applying voltages to the gun electrodes. This results in a fresh burst of electrons which theory being will allow more emmisions in normal use.
Usually this will help and a better if not good display is obtained afterwards. Downside is that it is still a temporary fix and the tube will go off again later on. Best is a new tube. You can regenerate tubes a few times before no more life can be squeezed out of the heaters then its a tube.
Hopefully I have this right and might offer some help when thinking of doing it.
porchy
994CR
Pretty much although you can target specific colours and not the heater specifically.
You can check the current state of all the guns before deciding to do any kind of regeneration too.
Ive had some really good results on the 2 monitors ive used this on but its not a device to be trigger happy with and you really need to know when to quit
lix
546CR
I have a BK Precision 467 which I picked up for a tenner from Deptford tat market in South London which is a place where all kinds of electrical crap that washes up in the local recycle depots gets picked up by various rag&bone stall holders and flogged to old hoarders like me. I've seen some crop up on ebay UK over the last few years, going for £40 / £70 / £120 kinds of prices depending on condition or having all the CRT base adaptors and manuals. I've only ever needed base number 23 though which should fit the majority of arcade monitor tubes, and there's wiring info for that base out on the web should a new one need making or sourcing.
So if you can't find any on ebay (there's a couple in the US usually) then I'de have a rummage around car boot sales or scrap markets if you can.
The only experience I've had using the device has been on a couple of poor tubes, one which I didn't really care much about so gave it a good whack with the 467 and it made a very slight improvement. Another tube I didn't want to risk destroying was just below the good levels and I couldn't really get it any better so had to leave it.
Ordyne
1,282CR
There is only one heater in a crt and if that's bad there's not much you can do about it apart from up its voltage (6.3v in most cases) to try and squeeze some more life from it.
Its the electron guns you're rejuvenating, most of the time you're just going to have cut off & emission problems. Quite often you will get rid of the cut off problems and bring the emissions upto a usable level but its uncommon to get them back up to orig spec in my experience. Older tubes are better candidates, stuff from the last 10 years is pretty much bin fodder!
I can recommend the Sencore CR7000, its a pretty cool bit of kit and goes a little bit beyond what most rejuvenators do/how they do it but they aren't cheap.
