CRT Reversed Image
Chopper79
668CR
Just fitted my polo 2 chassis, and the image is reversed. I'm certain I wired it correct. I tried the yoke plug in both available sockets on chassis, and still the same.
Doctonic
9CR
Red/Blue wrong way round? Although it probably isn't that simple :) This kind of post is what happens when I am bored and not working :)
Doctonic2019-11-26 15:34:59
Chopper79
668CR
Yes, I just reversed the 2 wires and it fixed issue. It was actually the vertical 2 wires swapped over that fixed it. I first tried the horizontal wires, and the image then was upside down!
big10p
Coins detected in pocket!
6,093CR
Kind of makes sense. I remember reading somewhere the beam is actually deflected at 90 degrees to the coils, so the hori coils are actually the ones on the top/bottom of the yoke.
tb2000
3,584CR
You must have them labelled wrong or something, because it's definitely the horizontal yoke wires you swap to flip the image in your pic
. If you'd got them plugged round the wrong way - as in horizontal yoke wired to vertical deflection circuit etc. - then you'd have had a faulty chassis and/or yoke at the minimum as soon as you'd plugged it in! If you're fitting a fresh plug and terminals on a prewired yoke, a little tip for setting up the image orientation is to insert the terminals into the plug the wrong way round - as in the opposite way round so the little "leg" on the side of the terminal doesn't catch in the plug to lock it in place. You'll need to press them into the plug with the small screwdriver when you push the plug on the socket on the chassis as there will be nothing to hold them in the plug at that point and the socket terminals will try to push them out of the plug. You can then try it, then switch off the monitor and swap them around if need be to get the correct image orientation. Then when you've got it right, just swap the terminals back round to the correct way so the "leg" catches in the plug and you're done.
tb20002019-11-26 20:46:14
