Crt screen
Pharo
266CR
Hi all I picked up a s.c.i arcade last week and it plays great but I've noticed when I switch it on the first time nothing happens just a loud buzz so switch it off and back on and I get a rolling green screen with the same buzz but it gradually gets quieter and quieter till nothing then the screen bursts into life with the game is this anything I should be concerned about.
Cheers Brian.
Pharo
266CR
Cheers Ronnie will try and get a picture or something tomorrow, when the crt does come on the picture is as bright and as sharp as any crt I've seen in a cab before with no burn.
6,091CR
The game board doesn't seem to boot straight away? Check PSU voltages when you switch on. If it's a Hanty one, it's probably failing. They're pretty notorious.
Pharo
266CR
Had some time today and it's definitely the psu it's as if it's taking time to get to the right voltage very slowly then it spikes to what it should be.
Here's a pic it is a hantarex.
The crt is a mtc-9000
r-type
633CR
The hanty PSUs can be repaired (I think Gunblade does them) although it's quite expensive. It might be cheaper to source a new ISO transformer for the monitor and JAMMA PSU for everything else. That's what I did in the end anyway, but had a spare ISO and PSU lying around. I can guide you through it should you want.
8,290CR
I have a us150 hantarex good W O
( same connector type )
If you get short on options £50 posted.
I’m not familiar with this cab.
But you might want to see if you can get a new psu that with some changing of your connectors supplies a correct and long term stable solution for your power requirements
