I know how you feel, nothing near me would touch them, the place down the road had some old guy who used to service CRTs but he said no too.Yeah I've tried contacting a few local to me, (Ware, Hertfordshire) but most seem to repair newer TVs only. Just wondered if anyone could recommend someone specific.
I've used Ed (for PC CRT, PVM, BVM repairs) - can recommend - he's very busy though!There is a guy on Facebook called Ed Mullard, he has a shop that repairs CRTs - haven't used him myself but seems to have a good reputation.
What the issue , you say geometry can you be a bit more precise? - I am based North jent and service crt, mainly pvms and Hantarex but might be able to helpAnyone know anyone in the Herts/Essex area that can service CRT TVs? I have a Sony Trinitron 21inch that has a geometry issue that isn't solvable via the service menu and I don't have the experience/confidence to open it up.
Hi, thanks for your reply. Perhaps these images would help clarify what I mean. It's drifted so much to the left that I can't move it back to center with the service menu.What the issue , you say geometry can you be a bit more precise? - I am based North jent and service crt, mainly pvms and Hantarex but might be able to help
I don't want to throw bad karma to anyone I haven't dealt with personally and know to be providing a poor service, but there was at least 1 guy on the Facebook pages that was mighty unimpressed with the service from Ed - so it might need more research to decide if he is good or not....There is a guy on Facebook called Ed Mullard, he has a shop that repairs CRTs - haven't used him myself but seems to have a good reputation.
I was thinking about using Ed for one of my CRTs but after doing a quick Google and came across this thread on Reddit:I don't want to throw bad karma to anyone I haven't dealt with personally and know to be providing a poor service, but there was at least 1 guy on the Facebook pages that was mighty unimpressed with the service from Ed - so it might need more research to decide if he is good or not....
Hi HideousHi, thanks for your reply. Perhaps these images would help clarify what I mean. It's drifted so much to the left that I can't move it back to center with the service menu.
I can't remember why it happens, but it's a known issue with lots of consumer tvs (RGB left shift). This also happened on them when new. The pro monitors usually have enough adjustment to overcome the issue, but the consumer sets had lower tolerances so you have to put up with it. You might be anble to compensate with some overscan? Just to say, Gerard at VIS has a good rep and is as good as anyone if you want a PVM serviced.It will only go further left so no amount of adjustments will sort it unfortunately. It's OK for tate games but playing normally it's quite frustrating.
Not sure what they're getting at there when they say "more dangerous than regular TV tubes". They're literally no different - in fact as we know some TV sets have got crts in with identical part numbers to crts found in arcade monitors - and they're A designation crts same as in 99.99% of TV sets (I believe there's a tiny amount large crt TV's with M designation monitor quality crts in)! Also, all "modern" (late 70's,1980's onwards) chassis work on either isolation transformers or have built in switch mode psus, no more dangerous than a normal TV! And K7000's aren't hard to work on! I'd say arcade chassis are safer to work on those earlier TV's with valves and exposed wiring everywhere, as well as lopts with more "on show" - most lopts in those older TV's used to have to have a safety cage round them from what i've seen!There's a guy not too far from us, Belfast area, that repairs old CRT TVs going back to the 1950s, as well a valve radios. We left a WG K7000 with him a while back and he came back to us and said he wouldn't touch it. Couldn't get a proper answer as to why not, except that they are more dangerous than regular T.V. tubes. Thought these would be easier to work on since no tuner or audio to worry about.
I'm fine with recapping and flyback replacements, but to further investigate issues is a wee bit beyond me, but still learning.
