Cut off MVS battery?
ZuPoint
20 (100%)
138CR
Hi all
I've got my neo cab working great after a few multi slots going the way of the dodo.
To stop my 4 slot going in the same direction should I cut the battery off?
I've got a unibios fitted from silver fox .
I don't have the steadiest hands to solder a coin holder onto board to replace.
Does it need a battery?
Could I just extend the cables and fit external battery?
Any help would be great.
Carl
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
YESSSSSSSSSSSS
cut the battery off ASAP
that's the main cause of a 4 slot death
no it don't need a battery all it does is book keep and keep date and time which is never used in a home environment
yes you can stick 2 wires on and fit a 3.6 volt rechargeable battery away from the board
make sure its rechargeable or then do the battey mod so you can use a normal 3v battery
silverfox07862014-08-18 19:13:57
