Damaged chip?
bones
1,628CR
Yeah that convertor probably works ok, I couldn't get one going when I put a LCD TV without a VGA connection in a pump it up dance stage, same thing no signal. Ended up sending the computer and convertor board to gunblade(Grant) and he set it up and it all worked fine. He said you need to set the resolution option correct,thought I tried all that, I think you have to hold down the menu button or something when you power up to access the menu's,then select English as the language which makes things a bit easier.
Mark
3CR
Update.. finally! Got the new converter and things seem to be %100 working!
