Dark VGA CRT.
darkomen
1CR
Hi all
I know this isn't really arcade related but this is the only place i can think of which would have knowledge of CRT's these days.
I've just got myself a nice Packard Bell PC all original and working but I've noticed the screen is a little dark... Some games i can increase the gamma which helps but otherwise it's just way too dark. I'm guessing this means it needs a recap or something? Not too clued up on CRT's so looking for advice and maybe a repair if it's even possible? I had a chassis fixed by Gunblade ages ago which was perfect. Not sure if these work the same way or are serviceable?
The text here should be a shade of grey and you should also be able to see faint clouds but it's completely blacked out. Obviously brightness and contrast on the monitor itself is maxed out.
Unreal Tournament looks good WITH a gamma increase.. otherwise its way too dark. The intro to the game is barely visable.
darkomen2021-01-08 17:17:37
8,308CR
i used to have that monitor....
xwing vs tie fighter
magic carpet
doom
the flyback has a brightness preset but might not
be a accessible form outside the monitor casing( and always read safety when touching monitor flybacks can kill!
sometimes monitors go dark from usage...
literally the tube part burning out bit like the sun!
they don’t have infinite life.
but may just be flyback needs a tweek..
eventually over increasing volts on the flyback produce visible mask lines in the screen..
some monitors have access to flyback brightness amd focus on rear of monitor casing
darkomen
1CR
I thought so, yeah I'm well aware of the dangers of CRT's I never work on them.
Given the condition of the rest of the machine I'm not sure if its down to use but i could be wrong. I've installed the ATI control center which has gamma settings which works on everything inside Windows so that will have to do. It's a shame CRT's are reaching the sort of age where they are starting to fail.
There is nothing like a CRT... Silky smooth motion and zero input lag.
