- Credits
- 765CR
This repair is really fighting me...
I've replaced the ram, replaced the ram sockets, replaced the 74ls367 @ U5.... still a scratch ram error.
I've hooked the logic analyser onto the RAM decode PROM @ U24, at first look it seems that I have invalid input/output combinations. Looking at the dump of the prom that I found online, I think....
All address lines (A10-A15) low should give me low on pin 12 (output bit 0) and high on all other output pins (11,10,9) which should give me low on the select pins of the RAM at U19 and U30)
A10 high and all others low, should select U18 and U29 via a low on U24 output pin 11 (bit 1), all other address combinations should drive all output pins on U24 high, deselecting all ram.
Anyway, since I don't have a PROM reader (the data io 29b IS my prom reader) I'll knock something together with an arduino when I get time to read the U24 prom out of circuit. If it is dead/corrupt I'll probably knock together a small logic board or something to replace it to get the programmer working so I can replace it with an 82s129.
Cheers, Sam
Cheers, Sam
