Data IO 29b - Troubleshooting
Purity
The Oracle
2,999CR
Equites said:
Macro said:
just a ps to this thread - this popped up on the tech tools forum may be of interest.
Actually there is a great support group on Yahoo for the Data I/O
programmers - I joined it years ago and it is moderated by Alferd Marin
who bought up all of I/Os obsolete gear. Alfred is a great help, often
giving advice on setups etc. for the various older I/O gear.
Go to Yahoo.com and look for the DATA_IO_EPROM group - easy to join!
Tons of archived info on upgrading the 29 series machines including
adding more memory and getting them to the last revision level. Well
worth the visit!
Thanks Mike, I absolutely give up with this thing. My only other option right now is to try and get my hands on another 29B unit.
I now believe the problem is with the programmer, where exactly is a mystery. It is either the main unit or the 29B UniPak. I need to eliminate which one with another working unit.
Quite frustrating, I needed to check 2532 ROMs today on a Pacman and don't have the facility.
I might be able to help here. I think my programmer can read them, if you still haven't done so.
I 'm sure it can definately read TMM2532. What's the specific manufacturer chip type?
Equites
Chief Sheesher®
35 (100%)
3,332CR
worth the visit!
They are TMS2532A, apparently used on a lot of Williams stuff too.Equites2014-10-18 13:09:40
4,058CR
For reading it's easy enough to make a pin adapter out of a socket so you can read them as 2732. I've done that before for PCBs that needed a new 2532 and I didn't have any. No good for writing though.
Equites
Chief Sheesher®
35 (100%)
3,332CR
Martin, thanks for that tip, I'll make an adaptor up for next time.
Luckily Ben popped down with his programmer to read those ROMs for me.
Macro
2,016CR
As long as the programmer supports 21v for VPP then you should be able to program them using an adapter as well - I used to use one with my Willem programmer (before I bought 3 others that all do 2532's natively!)
Equites
Chief Sheesher®
35 (100%)
3,332CR
I am resurrecting this thread.
DanP was kind enough to loan me his working 29B Unit and UniPak, and I can confirm that it literally worked right out of the box.
Unfortunately, I have been able to confirm that the problems with my setup are both the 29B unit AND the UniPak (by process of elimination - Sheesh).
At this stage, I am not sure how I am going to proceed with this, if an attempt to repair it is even worth the effort.
Many thanks to DanP.Equites2015-01-31 17:13:29
Equites
Chief Sheesher®
35 (100%)
3,332CR
porchy said:
thats bad mate.
Hope you can get if fixed. If there is anything I can do then let me know
Thanks Jon, I've got a fighting chance with Dan's unit here to compare against.
I think the first thing to do is to get the main unit working.
I noticed that the SELF TEST on boot takes MUCH longer on Dan's than it does on my unit.
NivagSwerdna
855CR
Resurrecting this dead thread...
I'm trying to get my Data I/O 29B to talk to the PC for the first time... I plan to write my own software based on YAR https://github.com/ieure/yar ...
Attached a USB Serial interface to pin 1 and 3... and using the SELECT FA function tried to get some characters sent across...
I applied a scope to the output and it looks like garbage... it has some bumps but not enough and doesn't appear to be driving correctly...
Has anyone tried replacing the MC1488? or maybe problems with the voltages driving it?
I need to get courage to take this thing apart!
Equites
Chief Sheesher®
35 (100%)
3,332CR
I wouldn't worry about taking it apart, its quite well built and not tricky at all.
NivagSwerdna
855CR
Put the scope on and using SELECT FA to send AAs...
The switch on the back points to 12 which I think is 4800... the DIP switches inside are harder to interpret but...
which I think is OFF, OFF, ON, ON... which is No Parity, 1 Stop bit.
Anyway I think the trace above is barfed so must be the driver? MC1488? The fact there is something probably means the M6850 is trying?
yorkshire_spam
765CR
Just checking (from memory) are you using the right Select command on the base unit - when I use mine via serial on the promlink I do:
select
f
1
start
start
to get it going.
NivagSwerdna
855CR
Select F1 Start Start is for Remote Control Mode.
Select FA Start <ascii-code> Start, Start , Start ... is for testing
I've ordered some DS14C88 and will now wait until they arrive...
NivagSwerdna2022-02-04 14:20:43
Purity
The Oracle
2,999CR
F, 1, Start, Start is correct and it should say "Remote" on the display or something similar
I think I did try and get a USB to serial working on mine, and it just wouldn't work, so I ended up building my own adaptor and finding an old laptop/desktop that had the correct port
yorkshire_spam
765CR
Ahh cool. I couldn't remember what I read in the 29B manual about serial modes, just which one I used.
NivagSwerdna
855CR
OK... so I couldn't resist...
Measured -5V at pin 1, +12V at pin 14 of the MC1488P at U9 so that is correct.
Measured 76.77kHz at pin 3 of the 6850 which corresponds to 4800 baud so that is also correct.
Looks like I need to remove and socket U9 and then try a new one.
Removing the PCB from the case looks tricky... and I do need access to the bottom to install a socket properly.
NivagSwerdna
855CR
Well after some hard thinking I realised I was counting pins incorrectly! 1 is on the right not the left... once I solved that problem all was good!
(The pins I previously was scoping are the 20mA loop... not so clever)
