I don't know if anyone else has this programmer or if it's just me - it was after all an arm and a leg!
Just a heads up that I've discovered that in the IC test for 4000 series logic, the test for 4016 logic isn't reliable. At least on mine anyway. I pulled 2 x 4016's from an MCR sound board at the weekend, tested them and it reported them to be fine. So I discounted them as being the problem.
I really should have listened to my head as hours later having been all over the relevant sound section, even down to resistor and capacitor level I decided that it really HAD to be those two at fault anyway, replaced them and all the sounds channels came back working.
SO, I've been in touch with Dataman this morning and this evening I will complete the required diagnostics report on my programmer (it could, at the end of the day be my programmer!) together with the log window of the IC test and will send that off. I will also be sending off the faulty devices and a datasheet so they can correct the issue. I have heard they are particularly good in this kind of situation.
If I can find a datasheet for Intersil 5610 proms then they're going to look and see if they are similar enough to an existing device to add support for that as well without needing example devices (I only have about 6 left!).
To be fair, that's what I call service so watch this space...
