Hi
The plastic panel is the first part connected when building up a panel so you do pretty much have to take the whole panel apart to get to the speakers but it isn't too difficult.
Remove the 4 security bolts in the corners to disconnect the CP from the cab. either pull the panel forward to get to the loom behind or open the back up and disconnect all the wires connecting the panel to the main loom, maybe an earth wire or 2 also.
Once off the cab you need to remove the wheel, single bolt under the centre cover.
Take off the gear shifter, 2-4 screws holding the bottom cover on.
4 security bolts on top cover, followed by 4 screws and then 4 bolts holding the shifter in place.
There are then 4 nuts holding the steering mech to a metal mounting plate once removed you should be able to pull the heavy mech from the panel.
Finally the mounting plate is held onto the plastic cover by a couple of security bolts on the front behind where the wheel would be.
You might need to disconnect the VR panel and tweeters from the loom as you go and you may be able to get access to what you want before you completely strip it apart so go as far as you need.
The above is from memory but thinks it's accurate. and assuming you have a Daytona Twin style cab.
Setch.
