As above I would agree it is probably the feeedback pot (there are two pots, one for the steering and one for the feedback.
Press the test button (inside the coin door or on the i/o board) and go to Drive BD test
With the steering wheel centred, it should be around 80H (between 7DH to 84H are close enough). the drive board will have a 7 seg display it should have a hexadecimal number close to then handle value on screen (+/- 4). It should change as you steer the wheel.
If not you need to go around the back (or remove the steering panel) and you will see three plastic gears on the wheel, the top one is the Handle and the bottom on the Drive Bd. Remove the screws holding the bracket and adjust the pot until it is 80h (ceheck to see if the gear is broken, replace if you need to), replace and screw back down, it may change but as long as it is within 4 of 80H then everything should be okay, I would take the time to regrease the gears with a little lithium grease too.
I could also check to see if the clutch drive belt has fallen off or is loose.
