decent PSUs?
andyJay
98CR
evening chaps
after picking some brains on decent arcade psus that are available.
so far from reading around suzohapp and meanwell make decent arcade supplies.
thing is meanwell isnt very well regarded for PSU's in the IT sector,same as a lot of mainland chinese suppliers.usually the noname capacitors are crap (longdong,samdung are modern classics) and the regulators tend to fail due to using the case as a heatsink to save cash and really sh*tty heatsink bonding,can you tell ive had experience with these things? :)
so with that,what PSUs would be recommended for decent ripple/noise and long life,and has anyone used the prima power psus for a decent amount of time?
cheers guys.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Prima / Suzohapp are probably the best 'arcade' power supplies you can currently get but they aren't going to have the best 105c / japanese caps in them. I think they only way you'd get that is if you recap them yourself or use a high end atx power supply.
Old switchers didn't have good caps though or even short protection like the new ones do and you don't hear of many cases of boards dying when they go bad.
Sbdesign
SEGA collector
16 (100%)
1,722CR
I wanted help with this too, I need 1 x jamma psi, and only checked out ebay, and put it off.
cab out of sight out of mind, but this just reminded me I need to get cracking on with it.
Anyone got links to good suggestions?
Im gonna run a STV with this most likely.
andyJay
98CR
that was my main worry with not having adjustable 5v,i can get hold of some decent server psus that should fit in the bottom of one of the cabs,might need to move the transformer and bulky fuse board out the way first.
sbdesign:
in the meantime just to get up and running i got hold of a prima power psu from arcade world,
no way in hell im going to power up the rusty kortek supply thats in there now!
https://www.arcadeworlduk.com/products/Black-Arcade-JAMMA-Power-Supply.html
found this as well,prima power is suzohapp?:
http://www.ukvac.com/forum/best-psu_topic348960.html
penrhos
747CR
I'm running two of those arcadeworld psu's without any issues.
I'm lucky as I managed to pickup some 110/220 switchable Sanwa psu's from yaj for the equivalent of £35 each.
IanH
277CR
I'd deffo try the server psu's. I've used pc psu's in videos cabs at work (i'm a arcade engineer, or I just 'test' the video games for hours) and never had a problem, maybe I've been lucky...…
If you do use a jamma type black psu, put a fan on it. Doesn't have to have massive air flow, just enough to help cool. Makes them last much longer.
Ian
IanH2018-06-21 02:03:12
andyJay
98CR
Already done ian
nabbed a few panaflo screamer fans with dust filters off a scrapped server,probably have one on the monitor chassis,game pcb and psu,should make everything last a lot longer.
Being an arcade engineer would be my dream job,beats fishing cat hair out of laptop fans.
andyJay
98CR
cheers for all the feedback guys,going to do the big switch on tomorrow,will have to calibrate the 5v line and mess with the monitor,fingers crossed should be playing super hang on tomorrow night.
