Decrease resolution of optical encoder?
P-Man
International man of mystery
1,273CR
Once again, we can't help you without knowing the connectors you'll be interfacing with. If you really need step by step instructions then you'll need to be more specific.
strykr
1,351CR
@alpha, yeah Dsyde found 2 when he did one of his electrocoin salvages,
P man, i have the Wheels Runner PCb, and currently I have the jamma harness going into the pedals (basic microswitch) and have taken a 5v and a ground off the harness and the left and rights from the wheels runner pinouts to player 1 and player 2 Happ wheels mounted on the cab ala badlands,
the opto pcb in the wheels im 90 percent sure are these ones
if its not this one its pretty much identical and takes the same connections.
strykr2013-03-15 18:52:39
P-Man
1,273CR
That looks to have an IC on the pcb there, its possible that this is giving a different clocking speed, you could try putting in a regular atari steering encoder...
strykr
1,351CR
Forgot I actually do have pictures of inside the wheel
Interesting idea pman, could be worth a try. I would love it if it was that simple, its more then likely that the cab I played on bitd was a badlands conversion I guess, which would have had an Atari wheel, Do you have one by any chance?
strykr2013-03-15 18:59:54
tb lilley
5 Star
1,686CR
Just to complicate matters ..... If you do go the Atari route make sure you get the correct encoder board:
Here's one from Missile Command:
Here's the same one, but has what I believe has a flip flop IC fitted (by the Made in USA text):
Not sure which games used the encoder with flip flop ....
strykr
1,351CR
Yeah I had a quick google for Atari optos and saw that one TB, not really sure what to be looking for really, most of the pics i see are from peoples hacked up mouses on byoac!
If anyone has any information or even better an opto from either a badlands wheel or pole position or something please let me know, even if i could perhaps just borrowed it to try out the theory.
Im still trying to wrap my head around the flip flop thing if anyone wants to help an electronics dunce out.
strykr
1,351CR
Also, out of interest, would doing something like covering every second hole on the encoder wheel effectively halve the rate, or is that a crap idea
strykr
1,351CR
Cheers James, im slightly concerned that the optic layout is curved though, and the one on the happ is straight. gonna take a bit of hacking to get it to fit I think. and there isnt an IC on there at all, I dont know enough to know if that is a good thing or not?
Might be worth a punt though.
strykr
1,351CR
For $17 bucks i'll probably have a go, does anyone else need anything? i'll add them to the order. small things prob best i'd like to try and avoid customs. things like Atari cones and similar. There is some good stuff on there.
Equites
Chief Sheesher®
35 (100%)
3,329CR
I've got an encoder from a Konami GT cab I smashed to peices, it is definately Atari compatible as I have some tech sheet it came with showing different designations for different driving games.
Don't worry, it was an Electrocoin cab and therefore needed to be killed as it was badly swollen and rotting (made my job easier).
strykr
1,351CR
Great stuff Equites, would it be possible to borrow it off you, see if it does the job?
tb lilley
5 Star
1,686CR
It needed to be killed, full stop - irrespective of swelling / rot. Well played.
Equites
Chief Sheesher®
35 (100%)
3,329CR
You can have it mate.
Equites
Chief Sheesher®
35 (100%)
3,329CR
You know it......
strykr
1,351CR
Cheers mate, very decent of you!
