DEFENDER Crashin
2CR
Hi there need some help identifying an issue with my Defender. It is in constant use in an Amusements arcade and every day around 2 o clock in the afternoon the image on the monitor freezes. I turn it off then and again the next day at 9:30 and it runs through fine until the same time again when it freezes.
Have had someone say this may be a powersupply issue. Just wondered if anyone could help out or has had any similar issues.
Thanks, George
Rasputin
71CR
My Defender used to randomly reset and corrupting my high score table but ever since I replaced the Nvram with the original chip and retrofitted a coin battery it's been as good as gold.
DanP
Administrator
2,232CR
If you're going to run it in an arcade environment it's probably worth replacing the PCB set with a modern JROK set. It will play exactly the same but be a 1000 times more reliable.
HTH
Dan
