Defender: Mirrored screen sections!
Judder
1,009CR
Hi everyone
Hope you are all well
So after upgrading my backup Defender CPU board to 4164 RAM it was all working fine, still after a while the screen started 'doubling' up
Basically the bottom 1/2 would then show twice, and over time reduce completely to just a line at the top of the screen
Video here
In my head this sounds like dodgy address register chips mucking up the memory addresses to the RAM chips but wondered if anyone else had similar thoughts and which chips they normally are to replace?
I guess it could also be the decoder (P)ROMs but that seems less likely as they tend to work, or not
Thoughts all welcome!
Regards
Alex
Judder
1,009CR
Thanks Chad - I'll give them a re-seat and see if it makes it happy again - might have knocked them when installing the (nearly endless amounts) of replacement memory
NB: Need to work on a single chip memory replacement for these boards... ;)
philmurr
48 (100%)
2,378CR
I’d check the counters at 5E-5J first.
If ok then check the mux outputs (the 153’s are the usual suspects that fail)
Edit: after doing what Chad said :)philmurr2018-05-17 17:02:36
Judder
1,009CR
Good news - I think Chad is right
I am using 2716-20 EPROMs to replace the PROMs on this board and maybe they had come slightly loose on connections as after reseating both of these it now seems to have dropped the 'mirroring' behaviour and is playing fine
Thanks guys!
chadsarcade
Lord of Vectors (tm)
443CR
Nice one Alex!
In my experience, problems with the counters and 153 usually show as problems with the rug screen, and the game doesn't get past unit ok.
Chad
