Defender not booting
bbz149
26 (100%)
1,608CR
With machine off, I would gently tap the ROMS with a screwdriver handle encase of bad connection in Socket, Also the Ribbon connector on the ROM Board try sandwiching between 2 bits of Wood and add a little pressure in Vice to re crimp as those connections sometimes go bad
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Led 1 and 4 lit like that on the rom board indicates bad ram. First check you have 12v and -5 which are required for the 4116 rams.
We know you have 5v as it's trying to boot, also don't leave it on too long if either 12v or -5v are missing as that can kill all the rams.
andyman
1,059CR
You have no 12v going by that PSU pic...check the LM723 @ IC2 and the 3055 transistor...and the components around it...Ignore the 3075 reference...its meant to be 3055
andyman2020-05-25 00:46:59
LawmanAUT
80CR
Not sure if it helps but I installed the online highscore savekit. It has the advantage that you no longer need the rom board ( with these from time to time troublesome ram ). Since its plug and play, you can always go back to 100% original.
Body pop
24 (100%)
1,266CR
I’ll get a look at it today thanks guys
If it turns out to be the power supply ,does anyone recondition these or sell them reconditioned
Body pop2020-05-25 12:06:26
