hi guys,
got a weird issue with defender.. the ram is all cooked (literally). took out all the 4116's and all voltages now fine. if i put them in one by one and watch voltages, first 8 fine, then 9th chip (irrelevant which 4116 or which socket) causes 12v to hit over 18v. (measured at power supply and ram socket). Looked at the 723 regulator and watching when putting chip9 in, pin 10 increases in voltage and pin13 drops in voltage. im guessing the 723 is not at fault as pin13 is labelled as input therefor i guess the 723 is doing what its supposed to be doing. My question is what controls pin13(input) ? Its marked on schems as +7.2vDC. Where does this come from ?
Thanks for any ideas.
Kev.
Kev.
