Defender Upright Screen Wobble.
Lenty
104CR
Hi All,
Progressing well with me Defender project. The picture wobbles from left to right. Tried adjusting a few pots with no luck. I notice the monitor is a Philips MVA48ABK05X. The chassis model number is OC-W.G and on the board it mentions KS-10. Any advice on fix or how i can be 'wobble free'
Thankyou as always.
Mark
Lenty
104CR
UPDATE,
I thought i'll see if I have the same screen issue with the JRok board fitted. No screen wobble now all perfect. So does that mean i have an issue with one of the original boards pls?
Thankyou
gunblade
9,144CR
chassis info is not enough, likely to be wells gardner k4600 or electrohome g07 - photo will prove it
if the replacement board resolves issue then it could be to do with sync connection, i think defender is + sync
Lenty
104CR
Thankyou for your advice. What would be the next steps on me checking the + sync pls? As the monitor works fine with the JRok board am I right to think the issue is not there and with one of the original boards.
Lenty
104CR
Looks like this site does not accept MP4 videos that my Samsung records in. Let me take a video from my iPad and hopefully this will be accepted
Lenty
104CR
Makes sense thankyou, Do we have anyone on the forum that can check/repair this board if I send it to them. Fully understand this will incur costs to me?
Again thankyou
philmurr
48 (100%)
2,378CR
Again thankyou
It's unlikely the board is faulty and even less likely anyone can fix it...
Please can you get a photo of the largest board near the 4 pin and 7 pin connectors, there should be a pcb trace around 1cm long (that inverts sync). Just thinking, if it's currently putting out + sync and the JROK is putting out - sync it may be worth inverting it and seeing if that improves things.
Also please post a photo of the 7 pin video connector on the board showing how it's wired
Lenty
104CR
Does this help?
Thank you
philmurr
48 (100%)
2,378CR
Unfortunately my idea won't work. You have an early version of the Defender CPU board which doesn't do -/composite sync so your only option (without an external circuit) is separate positive sync which is what is causing you problems.
There are sync stabiliser boards out there that may improve the stability of your picture
