Deguassing wands
Evening all.
Has anyone got or used one of the green plastic deguassing wands that Amazon sell?
They look fairly cheaply built but more wondering if they do the job?
I have a cab with a Videocolour tube in that has no adjustable purity rings but has a bit of discoloration in one corner, drill trick won't shift it, so thinking about giving a wand a try.
pooman2084
Be Attitude For Gains!
26 (100%)
1,886CR
I was looking at them.
A few have advised against them but then again a few said they got good results.
I did bid on a better one on eBay the other day but got outbid.
big10p
Coins detected in pocket!
6,092CR
Is your degaussing coil working? If it is then getting a wand won't fix the issue, I doubt. More likely the shadow mask has been dislodged.
Yes it's firing still. Might be the mask then. It's not horrendous, may have to just live with it, just slightly annoying.
AnOldCabinet2021-06-10 22:33:32
big10p
6,092CR
Shadow mask then, I reckon. If you turn the cab to face a different direction, does the discolouration change? As it happens, I have a videocolor with the same problem. I had to fit a set of purity rings to fix it.
Wow... if you google 'fitting purity rings' you get into a whole other ball park... true love waits etc... definitely need to add 'to monitor' on the end ; )
big10p
6,092CR
5,414CR
AnOldCabinet said:
Evening all.
They will work, my only concern would be the safety aspect of them but some here have bought them and no issues
If its been magnatised quite bad even built in degauss wont sort it perfect and you need to do it manually so its handy thing to have, over the years ive had to use mine quite a lot
My Operation Thunderbolt could be a shifted shadowmask but its severe colour issues, really need to get investigate it and find out if it is or not, would be the only tube ive had in all these years that has moved, not very commonn, if it has the tube is scrap and i can replace, at least its one less monitor in my way then, certainly ne interested to know
Zektor
312CR
https://www.ebay.co.uk/itm/284315147797?hash=item423280de15:g:YpoAAOSwDmlgtPm1
You can use one of these for deguassing if you don't have a wand, hold the trigger and swirl it around the screen then pull it away before letting go of the trigger.
RygarR
413CR
AnOldCabinet said:
Evening all.
Those wands work reasonably well, but you need to be careful. For safety reasons, never leave them on for longer than you absolutely have to - as they're prone to over-heating. I'm sure they're fine for a minute or possibly more, but the degaussing process shouldn't take longer than about 20 seconds. If you do need to repeat, switch it off, let it cool down, and start again. When I was using mine on an old monitor, I had it plugged into an extension cord with an on-off switch, and used that to start and stop the wand.
vids
143CR
Bods said:
AnOldCabinet said:
Evening all.
m8 i can let you borrow my proper one i got from the usa years ago be a bit worried about posting though next time your this way let me know
gav
J69
281CR
I had a badly magnetised monitor. Tried using a drill but it was useless. Bought a green wand of death from China and it fixed the screen in 10 seconds.
Wear gloves and safety glasses when you use it
they work though J692021-06-12 16:55:31
big10p
6,092CR
they work though
Was it a cordless drill? Think it needs to be a mains powered one to work. Never tried myself, though.
