Desoldering ICs
4,058CR
a bit bigger than the diameter of the thing you're trying to desolder?
in all seriousness, that's impossible to say. Different components have different size legs, and different people will do things differently. Personally I use a tip that is quite a bit bigger than the component leg and 'waggle' it about (as bbz149 said above - forgot about that bit!!). What you really need is a tip that is the size of the solder pad, or very, very slightly just over. Not too far over or you will be burning the board and not heating the pad.
And 350C may be a little low. I am currently set at 365C. But I know that at that temperature if I apply the heat for too long I will lift pads. Heat will also depend on if the solder you want to remove is lead free or not.
dj_yt
787CR
Tried reflowing / waggling. This definitely helped clear a number of holes, although I still haven't got the blighter free. Needs a round 3! This could be a world record for most lengthy chip removal.
Unfortunately I damaged one of the solder pads with my initial effort which is a bit annoying.
dj_yt2015-09-23 22:45:36
Purity
The Oracle
2,999CR
Hold the area to a light - I just use a desk light, to see if I can see any holes that are not clear, and concentrate on those. I wouldn't try and remove the chip unless you have most holes clear
Purity2015-09-23 22:53:39
ColinD
6 (86%)
1,367CR
You might find that the corner pins won't desolder , due to them being connected to heavy power planes (Outrun is typical for this !!)
I tend to add extra heat with the soldering iron on the leg on the other side of the board.
You can also preheat the board *gently* using a hot air rework station.
grobda
1,061CR
I hold the board vertically in a hand vice and use a temp controlled iron to heat the leg on the parts side and a duratool pump on the solder side.
as a last resort you can always snip the leg halfway so theres a stub left on the chip. if you then flow fresh solder in you can usually melt the hole and suck the remaining leg out with a hand pump or grab it with tweezers. you can then solder a bit of wire to the stub and test/reuse the chip.
vib_ribbon
488CR
i do something similar and this is how i have the most success.
can't remember who taught me this now (maybe you?), but i clamp the board vertically, have a soldering iron on the leg from the parts side and the desoldering iron on the other. it's still not 100%, but i've definitely had more successes this way.
t-m
333CR
I use this thing mostly these days http://www.ebay.co.uk/itm/252020536679 works really well
I've got a desoldering tool but this is easier unless i'm doing lots.
Another tip I was told is once you've used the light trick to check all the holes are clear, use small pair of pliers with and angled tip, gently grab a few pins at the same time and give them a wiggle side to side - this will break any minute traces of solder left over without putting too much stress on any one pin.
KmanSweden
148CR
I use an old Aoyue 474+ you find them on ebay too.
Bought it used and just replaced the gun parts that ware out. It get the job done. I have been looking at a Weller one too but I'll milk this Aoyue (I-owe-you) untill it's dead before I pay up and the the Weller one.
dj_yt
787CR
Yeah that's exactly the problem I was having, and probably overheated those pins as a result.
I think in this case I'll just snip the legs (the chip was defunct anyway), and remove those ones individually.
A PCB holder is probably a good call also to try the soldering iron trick on the other side.
Equites
Chief Sheesher®
35 (100%)
3,332CR
I'll quote the wise P-Man, all you need is a decent Metcal Soldering iron and a proper hand pump.
I can't remember the last time I used my Hakko 808 desoldering gun.Equites2015-09-24 13:59:00
4,058CR
Nad: That funky blue sucker you mentioned above (somewhere!) - does it have a silicon nozzle? Ie, flexible and heat resistant?
I like the look of the one from Precision Tools and having bought from them last week I can confirm they are a great seller. But they're also not cheap.
4,058CR
Chip Quik is a gel based flux. I've used it for soldering SMT, although I don't particularly like it as it leaves a right mess behind to clean up, but how are you using it for desoldering? In conjunction with a hand desolder pump? A desolder station, or what?
