desoldering station
alfa75
19 (100%)
96CR
Does anyone have a good buying tip for a desoldering station? Mainly used for desoldering components (battery, RAM, etc.) on Arcade boards. Thanks!
alfa75
19 (100%)
96CR
Ace` said:
Hakko FR-410 if you want the best, Hakko FR-301 if you want a cheaper option.
Thanks, is the relatively high surcharge to the Hakko FR-410 to recommend? Respectively, I'll have limitations with the Hakko FR-301? I would use this frequently (weekly) to repair boards.
chunksin
21 (100%)
733CR
A bargain basement option is the Duratool ZD915, CPC often have this on offer, I got mine for less than £50 and the quality is surprisingly good for the money and it does the job just fine. I'm sure it wouldn't last as long and is not as efficient as a Hakko but I very rarely use it and spares are easily available and cheap.
Ah, just saw your last post, this is fine for the odd job and capkit here and there but not sure I'd want to rely on it for regular use
Chunksin2018-08-23 09:41:28
Ace`
PlanB contributor #1
40 (100%)
4,040CR
The station is more for people using it every day, it sounds like the FR-301 is all you need. The main difference is the weight as the pump is built into the gun, but if you aren't using it for hours at a time it shouldn't be an issue.
I personally wouldn't buy cheap or old models (again), I've done that before and that's why I have two in the shed that never get used.
I use a hakko 474 station which is the version before the FR-410 and it's fantastic.
alfa75
19 (100%)
96CR
pobtastic said:
I bought this https://www.rapidonline.com/xytronic-lf-8800-high-powered-soldering-desoldering-station-85-5490 although at half the price listed there. It was just on sale one day (on Rapid), plus I had some other discounts too. I use it often, can't fault it at all ~ it's an excellent bit of kit.
Thanks for the purchase tip, I already have a soldering station (WELLER WS 81), with which I am satisfied so far. Since my space on the table is relatively limited, I am looking for a solution with only one desoldering function.
alfa75
19 (100%)
96CR
You convinced me I'd get myself a Hakko FR-301. Thanks for your time!
alfa75
19 (100%)
96CR
As I will use it regularly I am looking for something in the middle class, I have had bad experiences with cheaper variants, so I always ask around before. Then I also have a scapegoat
But thanks anyway for yout tip!
alfa75
19 (100%)
96CR
Belike said:
I also use the ZD 915, works like a charm.
If I use it once a week for about 1-2 hours do you think it's stable enough? have you already used it on many arcade boards (for example for suicide battery?)
alfa752018-08-23 12:47:45
alfa75
19 (100%)
96CR
John Bennett said:
Good thread.
I normally borrow a Weller WR3M setup (heat pen, desoldering gun etc) and I'd love something similar for home, but the price is eye watering.
I'll be in Las Vegas in three weeks if I win, I'll buy these.
5,332CR
Thing is, even with £2000 worth of desoldering equipment, it's still horrible removing through-hole devices (and if you want them intact, even more horrible).
alfa75
19 (100%)
96CR
I have so far only experience with the desoldering pump and the desoldering braid and there I came very fast to my limits. I have already tinkered with it at several pinball machines but for an arcade board this is definitely no longer practical.
5,332CR
I find a desoldering gun is infinitely better than those, but I still end up finding I have to cake things in extra solder and heat it from both sides (awkward!) in order to free up the pins. Konami boards are particularly evil.
Maybe I'm doing it wrong, but even the training videos show similar techniques are needed.
So worthwhile 100%, but there'll still be some pain and a lot of time.
John Bennett2018-08-23 13:03:03
alfa75
19 (100%)
96CR
I think I will still decide for the Hakko FR-301, there is also the advantage that I can use it also on the way. And if I've the money and I've to do some more repairs I will buy the Weller WR3M or Hakko FR-410. Thank you guys, you are the best.
alfa75
19 (100%)
96CR
I accidentally powered my FR301-82 (100V) to 230V
, it made some noise at the beginning and then it became silent. My question now what could have gone broken? It doesn't smell strange nor do I see anything that is defective.
