What you've got going on the screen looks a bit like the horizontal sync pot on the monitor has slipped but its difficult to tell. In the video you have the panel disconnected then reconnected but the screen output stays the same.
The changing screen indicates different stages of the power up test, I can see where it would say "ROM OK, RAM OK" and then moves on so check the monitor for one thing. Either the monitor or in your investigating, a wire has come adrift in the loom from the sync although in my experience no-sync looks different to out of sync.
On the pot side for volume, you could get away with a different pot. I'm assuming you have an Atari board and AR2 is doing sound? Mine is a Namco board and the service panel pot is resisting the final output volume rather than adjusting the input feed which is how the AR2 works.
I think you have some latitude on the pot value but don't get a 200kOhm pot in there or you'll get very little control sweep. You could get away with 75 or 100 and of course the ampage/wattage I think can be as high as you want as that's just how much load the pot can take but if it's modifying the input it doesn't need to be high.
All that should happen is that the volume will be "off" a bit further into the pot if you use 75ohm than using 50ohm. Volume pots work in reverse from my limited knowledge - when the pot is to the right (zero resistance) the volume is fully on, when all the way to the left (full resistance) the volume is fully off. If the audio amp circuit is calibrated for 50ohm then if you use 75ohm as the pot value then at about 3/4's the way back towards the left the volume will have disappeared. Beware that too much resistance on a volume control can also do whacky things.
