Dig Dug Graphics Error
Danschki
65CR
Hi guys!
I bought a Dig dug that needed a monitor revision, now the whole thing actually runs quite well. i have only one thing that is not 100% yet.
in the start screen i have streaks across the picture, when the tunnel digging miner undermines the digdug writing then the writing drops down and the picture is normal.
in the game with the game figures and with the level display, however, stripes remain.
i am not the pcb expert, but does this look like a program error? is there a defective eprom?
if it is an eprom, is there any way to find out which one? i could have eproms burned, but i don't have the skills to find out what is broken.
here i uploaded a video so you know what i mean.
thanks in advance
Daniel
https://www.youtube.com/shorts/DEwJG_eW6-4
Danschki2022-09-27 19:34:31
Danschki
65CR
No one?
bones
1,628CR
Nice hi score, not seen this PCB,is it a boot or original and any chance of a decent pic of it. I've had something like that on double dragon boots but it's normally there all the time, usually a ram or bad ls157. Might be worth checking if your ROM sockets are ok and not those ones where there's only metal on one side. They age and lose their grip on the ROM leg,I change them as a matter of course nowadays. Obviously check the ROM legs are clean and if you have a multimeter you can check that the pin is actually making contact through the socket to the sockets solder joint. Just don't press too hard or you'll push the ROM pins onto the sockets metal bit while you test and after it'll be back to not making contact. Everyone will suggest slightly lifting the ROM up a bit and pressing it back down, but a photo of the PCB perhaps showing one of the sockets without a ROM in it might help people to offer advice. Good luck with getting it sorted.
cliff_poole
1,069CR
I think your guess of a bad ROM is a good one. The fault goes away as the code moves on, so the rest of the hardware is probably alright. As already said, reseat the chips first.
DaveR
367CR
i just had this but lines in sprites instead...its the double board namco version ... it was the little DD1=6 chip near the video connector plug, i just lifted a bit... its the tar on the legs
DaveR2022-10-01 10:02:37
