Dimmboard test results
Connorsdad
10CR
What is wrong here, anything to worry about ?
Game works perfectly
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
i had that once
its your dips
if you want to use in gdrom you need to set dips to gdrom and if you want to use in RJ45 net mode you need to set that way
then it wont show as bad
AndyGeezer
599CR
Your net dimm has damaged ics which are probably network related hence why your cf reader/gd-rom would work and not net booting.
4.02 firm is only for non sega cf cards anyway.
