Dino King sync issues
J69
281CR
I'm running a neo SD in my jammafied Dino King. Some of the games have an issue where the screen image drops vertically about 30%. The rest of the games are fine.
Does anyone else have a similar issue and how can I rectify it?
Flinnster
The Dino King
29 (100%)
2,566CR
Yeah that sounds pretty normal when the sync is slightly out. My guess is it's happening when you have something dark and then something light appears onscreen, or when the contrast of the screen changes quite quickly.
Are you running just the Neo SD, or other boards alongside it? Unfortunately, this is the downside of the Dino.. no easily accessible monitor pots. You have to go fishing with a plastic tool thru the letterbox of doom and pray a previous owner didn't do the same with a metal screwdriver.
To fix it you'll need to alter the vsync pot (V HOLD).. and sometimes the hsync pot (H HOLD). vsync is the safer to change by far, as hsync can lead to odd effects if moved too much so only do that as a last resort.
Flinnster2020-10-06 17:42:13
J69
281CR
Why not a metal screwdriver out of interest?
I've had a fiddle with the hold pots but it made no difference unfortunately. The fighting Neo games seem to be the worst culprits. Shooters tend to be fine
Flinnster
The Dino King
29 (100%)
2,566CR
Generally you are tweaking while the monitor is running. If you slip and short something metal between the chassis and metal frame using a screwdriver, or short two metal items on the chassis itself you may be heading to Grant asking for a repair.
Also you'll see the smaller pots on the Dino King chassis are really really weak. You can bend them back easily, and it's hard to feel them going when you are using a metal tool. At least with a plastic / nylon trim tool it's a little harder to exert as much pressure as with a screwdriver.
The pots can be straightened up and brought back into place - but you need to take the monitor out and access them from the sides, preferably with the tube discharged.
If you're altering the pots and nothing is changing then it sounds like someone may have already toasted your chassis controls.
Flinnster2020-10-06 18:34:39
  • Like
Reactions: J69
J69
281CR
I mean made no difference in regards to the screen still dropping with certain games. The pots work fine as the screen starts scrolling repeatedly when you alter the hori/vert hold J692020-10-06 21:16:53
