Dino King Vs. Kit Setup
Amb47uk
210CR
Evening guys,
Trying to do something exciting (for me) with my Dino King cabs this summer with big help from a friend who is much smarter at all this than me.
I want to create essentially a Dino King versus solution. (2 cabs, 2 control panels, 1 rgb-pi (jamma) system sharing the same video over 2 screens). The control panel setup is wired and working already.
What we aren't clear on is splitting the video feed, will a straight forward split be OK? or do we need a booster (ie ultimarc video amp) or some buffer to prevent any power surges/dimming etc.
Really appreciate any help/suggestions you can give.
Many thanks
Adam
thegreathopper
1,253CR
Jamma Vs kits do not use a booster, no problem feeding two monitors. I have one that I made up to link a couple of cabs. Worked great.
Good luck it’s great fun with two cabs linked.
neoretro
1,121CR
FrancoB
17 (100%)
1,040CR
I had some different monitors in my Love & Berrys (which are now in Flinnsters mass collection ) but they used a HD15 DSub the same as the stock monitors. To split the 15kHz signal I just used a VGA Y splitter cable which worked with no issues.
There are some pictures towards the bottom of [this] post.
Note, the monitors I had were tri-sync. To split the 31kHz signal I used a powered VGA splitter, that won't apply to you.
If both cabs are wired to JAMMA then you could make a JAMMA VS loom like this to split the video and audio to share between both cabs and also send the P2 controls over to cab #2:
That loom had a CPS2 kickharness built into it too, that's what the auxiliary cables are that are coming off the main loom.
Flinnster
The Dino King
29 (100%)
2,566CR
Yes so my loom was completely passive.
It simply maps cab 2's player 1 controls to cab 1's player 2 pins on a pass-through jamma adaptor.
The video is simply connected to both sets of RGBS cables and the same with the audio on speaker +/-
This was used at Revival to power 2 cabinets running co-op 2 player 'Demon Front' side by side. It could equally be used to create a vs. cabinet setup for fighters, however I didn't fancing my control panels being smashed to sh1t by the Walsall public, so went for a slightly more subdued game, controls wise.
Flinnster2020-05-07 12:24:02
FrancoB
17 (100%)
1,040CR
Lovely pics, makes me miss mine!
I know they're in their best possible foster home though
muddymusic said:
I love your loom work dude. You should do more.
Thanks for the kind words all. I would love to make cables again...or work on anything cab/project related at all for that matter. I sold up at the end of 2018 as I had a life changing move on the cards. I've been stuck in a tiny rented place for the last year whilst we sell once place and buy another.......which now may look like it could take a considerably longer amount of time
I can't complain too much though, I'm fortunate I have a roof over my head and I can still work. I am looking forward to some kind of 'normality' again though.
