Dipping my toe
tarkie
5CR
I've been a long time vintage computer collector focusing on 1978-1984 TRS-80's etc. I've decided to dip my toe in "Arcade" as a next step. I've collected together the pieces for a harness, arcade PSU, shotgun for Jamma, OSSC etc. pushed to a NEC monitor which is also able to go 15Khz
I have recently obtained a Gallag board as my first look at repairing arcade boards, and looking to collect some. I've also got a Gallag - Jamma converter.
Whilst this works for Neo-Geo, I just want to ensure that my harness is suitable for this board so i'm not focused on it not working when the harness isn't suitable.
Many thanks for any advice and guidance.
Lurch666
21 (100%)
4,517CR
Gallag is a galaga clone that looks like it's RGB signals come from a separate connector like on my pacland and gaplus boards.
According to what I found on the net the RGB might or might no be connected to the gallag edge connector so if you get no picture you would need to make sure your video is connected to the 5 pin connector on the video board and not just the edge connector.
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=pinout&page=Gallag.html
tarkie
5CR
[font="Arial, Helvetica, sans-serif"]Thanks Lurch666, the 5 pin on the board is linked to the Game to Jamma converter I'm using, and then routed into the supergun. Supergun then routes to the OSSC.[/font]
Lurch666
21 (100%)
4,517CR
Well I found the beast way to learn it to just try it.
if something appears on the screen then you have something to work with.
If the screen is blank then start by seeing if there is any activity on the RGB so you can tell if it's a board problem or an issue with your setup.
Lurch666
21 (100%)
4,517CR
Funnily enough it was fixing up vintage computers that got me started in this as well.
Picked up a Nascom II and took ages fixing it but during the process and help from the nice dudes at the Vintage computer forum I finally clicked on how digital circuits work including the way bus and CPUs operate so wanted to try fixing more stuff.
Since I already own most of the vintage computers I wanted I moved over to arcade PCBs.
It's a hell of a hobby and before you know it you might be like me and own 60+ boards that you have fixed.
