Discharging HV caps
big10p
Coins detected in pocket!
6,087CR
I've got to do a bit of maintenance to do on a PSU and wondered what method you guys use to discharge caps? Is it OK to just use a multimeter set to HV DC?
obcd
3,830CR
It's ok, but it might go slow.
Something like a 240V 5W light bulb does the job much faster.
There is an european law that all such capacitors should have a bleeding resistor installed.
It can be broken over time as it constantly is having a 380V DC on it. 220K-1M are values you could expect for such a resistor. It's always wise to check them with your multimeter before you start to work on those. It can be a shocking experience otherwise.
I seem to have read that Hantarex supplies are known to keep their capacitors in a charged state.
Battlezone
410CR
If it's just in a PSU, I'd disconnect it from any sensitive
electronics and put a screw driver across the terminals.
(I have one with a resistor and a lead I soldered on
but for an isolated PSU cap any insulated metal should
be fine).
Not tried using my meter.
obcd
3,830CR
Shorting charged capacitors is bad for their health. They are not designed for that.
Also, you will create a spark that can be intense and leave some visual traces on the capacitor wire ends and it's solderings.
Battlezone
410CR
No sparks for me because of the resistor, but it's possible an instant discharge may have an impact on the cap health that I've not heard of until now or run into.
big10p
6,087CR
Just checked the caps with a multimeter and get no voltage, so they must have bleeding resistors, I guess. All good. Cheers fellas.
