Discharging
PinballJames
3CR
Hi guys,
Just checking this looks all good, one hand behind back, no watches or jewellery - under the cap for a pop if there is one, if so, wait 30 and try again, rinse repeat until no pop when it’s safe... right?
Appreciate the help.
IanH
277CR
I'd do it with a plastic handle, tho I just use me multi meter lead with a crocodile clip anyway.
But looks good to me
funhouse
362CR
I put two wires and two clips on the screwdriver and chassis. I was scared that the test lead I had could fail and then I would think it was discharged when it wasn't.
DanP
Administrator
2,232CR
Don't use this screwdriver method with a vector monitor. It's fine for a raster one but for a vector you must use a real HV Probe to avoid damaging it.
obcd
3,830CR
Never put the ground clip on the chassis. Always put it on the wire that runs accros the back of the picture tube. That screwdriver looks like one with the metal coming out at the end so you can knock it with a hammer. That's obvious not the best type to discharge a tube. You need one with a plastic handle that is isolated on top. If you dislike the big spark, you can put 2 or 3 5Meg resistors in serie with the wire. It will now take a bit longer before the tube has discharged, but you will only see a very small spark. Some philips tv's had a discharge probe that had in fact some meg's resistance in serie.
funhouse
362CR
Good information in those posts - thanks.
Are all CRT devices possibly damaged if the chassis is used as the Earth then? Would OBCD's method prevent damage to them both?
obcd
3,830CR
Basically, the picture tube is a capacitor that holds a voltage. One connection of that capacitor is the anode cup and the other is the wire that crosses the back of the tube. I don't know the exact details but seem to remember the tube is painted on the outside with some conductive paint (the aquadag) and the wire should make contact with that paint. The picture tube is bolted to the frame, so, the frame is electrically connected to it and can be used for discharging. There is also a wire that is connected to the back of the tube that usually goes to the neckboard. From the neckboard, it goes to the pcb ground and from there usually to the frame. If you discharge the tube you can temporary get a voltage spike on the ground due to internal resistances, and that can damage some components on the board. For that it's better to discharge as close to the tube as possible.
Vector tubes tend to hold their anode voltage much longer, so the voltage you need to discharge is usually much higher. This causes a bigger spark that can damage the tube. If you use the slower discharge method with some 15Meg resistors in serie (preferable high voltage ones and spread over multiple resistors), you won't get the big spark. Obviously you need a well isolated screwdriver as you contact a >10000V point to it. While this is a scary high voltage and you don't want to know how it feels, it can only produce limited current. The high voltage used by the power grid is much more dangerous as it can deliver several amps and it keeps doing it. Those big bulky high voltage probes that show up occasionally are probably designed to be safely used in such environments but are not exactly handy to touch the anode point under the suction cap. Most discharge video's you find on youtube simply short the anode without serie resistors and create a scary spark. I have alwways used some serie resistors to avoid this.
Another thing important to know is that the tube recharges itself when left alone for a couple of hours. So before you reconnect the anode wire, it's best to discharge the tube once again. If you touch the anode connection otherwise, it might bite you again.
DanP
Administrator
2,232CR
I've reposted and stickyed Pman's original guide to discharging monitors from the early 2000s here. I've used it as my go to guide ever since. ymmv :)
69er
1,854CR
Brilliant … about time somebody did this … I did a similar thing on basic use of multimeters and safety while JAMMA+ was functioning and it had thousands of reads...………
I was horrified when visiting members homes to see the limited tools and number of exposed chassis and power supplies on show EVEN WITH YOUNG CHILDREN IN THE HOME
I WOULD JUST ADD ,( as mentioned by OBCD above ),, that when working with recently turned on monitors SOME tubes can develop a recharge while unattended during repair and ALTHOUGH THEY HAVE BEEN DISCHARGED TO REMOVE THE ANODE CAP >>>>>> ITS WORTH JUST RE-DISCHARGING THE HOLE IN THE GLASS AGAIN PRIOR TO RE-INSERTING THE ANODE CLIP it may be no charge exists but just checking takes seconds.
this is especially important as often its easiest to refit using your hands with the rubber pulled back to see and ensure the metal prongs engage fully with the rim of the socket hole
if the metal is not fully seated then it can lead to further future arcing around the anode cap due to the poor connectivity if its not secure … the last thing you need at re- assembly is a small unexpected spark shock when YOU THINK THE INITIAL DISCHARGE CLEARED ALL THE RISK … THINK SAFETY ALL THE TIME ………………..
****NEVER WORK WITH PLUGS IN UNLESS YOU HAVE TO HAVE THE POWER ON FOR THAT PURPOSE
its very easy to forget that electric is silent and lethal too... **** always buy and use a meter !!****
69er2019-04-23 09:47:31
obcd
3,830CR
You will need like 3 5meg resistors The reason I use 3 resistors is because 3 can handle the high voltage better than 1 and it's hard to find a 15Meg resistor.
I don't know if this method is safe for a vector monitor as I never had to deal with one.
It's just like a "cheap do it yourself" hv probe.
I am glad most of the article is identical to my rambling.
Ropi Jo
127CR
I swapped out hundreds of tubes BITD when I was a TV repairman. One handy little tool that was very easy to make is to take an old knackered LOPTX, chop off the EHT lead keeping it as long as possible, and crimp an insulated crock clip to the cut end and insulate the joint.
Once you've discharged the tube and removed the anode cap, get your new 'tool' and connect your croc clip to the aquadag and then plug in the anode cap. This ensures the tube stays dead as a dodo while your handling it.
I got caught out when I was a 16 yr old apprentice at Radio Rentals and got belted by the tube while carrying it after removing it, resulting in me dropping it. This was actually something the older guys set you up for, like an initiation! After that the simple 'tool' became a part of my standard kit.
Ropi Jo2019-04-23 19:19:12
funhouse
362CR
Great idea Ropi Jo and I have a spare flyback lead to use.
What about the resistors? The HV probes seem to use large resistors with many megohms.
Can anyone suggest what would be ideal with a vector monitor?
