Chunksin said:Here is the new v5.3 image, it has a couple of bug fixes in the service menu and the usb lag reduction config. I dialled down the overclock as I found it wouldn't boot on one of my 3B pis, you can edit the /boot/config.txt file to increase it. Check the overclock section, remove the hash at the start of the line to make the 3B+ settings active and add a hash to the 3B lines.
5.3 Download
Chunksin said:Are you using a pi2jamma board or have you built your own DIY setup? This image is for the DIY jpac version only, I have ported this to the pi2jamma but that is available separately from their website. I'll be updating that image very soon for 3B+ and the resolution switcher on that image is pretty darn accurate, it only screws up if the resolution data in mame is wrong which it sometimes is ...
Chunksin said:No probs, I'm updating the pi2jamma board image this week so I'll post back a link for download here when it's ready![]()
deanzor said:RE: bugs in the old version
Not sure it's a bug as such, but in there's no default set up for quitting back to the main menu from a game. I was able to set one up for MAME, but not for FBA for some reason. It's a minor inconvenience though, very grateful for what you've made![]()
I was using the 'thingy' build on pi2jamma.?
JonTron said:Hey.
I'm trying to diagnose a fault with my pi2jamms setup. Not sure if it's monitor, adaptor, rPi or program issue. Does the HDMI out of the rPi output at 15khz because of a change in the program or is that done in the jpac?
Basically trying to plug an HDMI screen in to see if it rules out my monitor or not and reconfigure the settings.
