Dome Screws
Flinnster
The Dino King
29 (100%)
2,566CR
Oh, not like these then? these are 4mm thread, for candy cabs:
retrob
41CR
If you mean carriage bolts:
Arcadeworld.com sell them but you can get them from loads of places, including ebay.
I have bought them from several places including getting some shipped from japan. The problem I find is that I can never seem to get the right size/shape head. Aesthetically they are always too wide or too small or the dome is right but the length isn't.
In my NAC I ended up using the ones from arcadeworld as they were closest to the stock ones but they were 2-3 times longer than I wanted.
retrob2018-06-01 19:53:51
Spaceman25
27CR
They are actually called coach screws! But the biggest problem as retrob stated they are normally too long! When I was trying to find ones 3mm which Taito tables use but nobody makes them unless you order tens of thousands!
4mm should not be a problem! You could try a company called Harrison and clough or Jaton who are fixing specialist or apex stainless ! They may not sell directly to you but will tell you who your local stockist would be!
Hope that helps
Flinnster
The Dino King
29 (100%)
2,566CR
Ah if they are coach screws.. I managed to get shorties for capping the holes at the sides of my dinos, but they were 6mm / M6 I recall - the lengths will largely be dictated by the bolt size:
