Donkey Kong video problem.
bountybob
38CR
Hi guys. I'm having an occasional issue with Donkey Kong where it powers up but doesn't seem to sync as seen in the photo attached. Any ideas what might cause this? I think it's almost certainly a board issue because if I use a DK Jr board this problem never occurs. It's a 2 stack DK board.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
There are two pots on the board that adjust vertical and horizontal alignment, this often get damaged or broken and cause sync issues, I'd start there.
bountybob
38CR
Thanks for the reply, good to have some kind of starting place. Is it possible that these only affect things at power up? Once it's on and working then it works fine.
bountybob
38CR
Zipper said:
If it's ok once left to warm up, then a monitor cap kit could help that.
Monitor was capped by RGP when I got it in February. Doesn't especially need to warm up, sometimes it comes straight on other times it doesn't but a turn it off and on again makes it right. And like I said, doesn't happen at all with the DK Jr board connected, so I'm not convinced it's a monitor issue.
bountybob2018-10-10 13:38:27
Monstermug
1,807CR
Looks like a sync problem. Have you tried to wiggle the P2 connector? If not I would trace the sync signal back to its source until you find the problem. Could be a failing chip..
Schematics here : [/url]http://arcarc.xmission.com/PDF_Arcade_Nintendo/Donkey_Kong_Schematics_(TKG-4).pdf[/url]
