Dorodon to ladybug
Lurch666
21 (100%)
4,519CR
Just got what was supposed to be a ladybug boot but turns out it's a Dorodon.Never seen this game before so It's a nice surprise as It's an interesting variation of ladybug.
I'm planning on keeping this as a dorodon but also want to see if I can get ladybug running on it with a different set of roms.
The first problem is ladybig cpu files are 6X4096 where dorodon is 3X8192.
I figured I could just put the six 4096 files as pairs into three 8192 eproms (2764) and it would work but all I get is squares moving down the screen.
I combined ladybug bootleg files
lb1a.cpu + lb2a.cpu into 1.3fg
lb2a.cup + l4.h4 into 2.3h
l5.j4 + lb6a.cpu into 3.3k.
Also tried on mame and got the same result.
Long shot but has anyone else got this to work?
GadgetFreak
963CR
If you look at the Mame source code for the game you will see that Dorodon has some protection in what look likes two 256x4bit proms. These combine as High/Low nibbles and make a simple 256 byte conversion table. I would say that replacing these with a straight 0-255 table would allow LadyBug roms to run.
You are correct to just pair up the rom files but I think you made a typo above as it should have been "lb3a.cup+l4.h4" for the second rom.
So it looks possible but the proms will be the issue, probably best to use an adaptor board and use some quick eproms.
virtvic
The Cabaret King
21 (96%)
2,013CR
I knew if anyone would know, it'd be our Gadget Freak.
Lurch666
21 (100%)
4,519CR
Yep that was a typo.Should have been lb3a.cpu.
I can sort the proms but what do you mean about a straight 0-255 table?
Should they be set up so each prom provides half a byte counting from 0 to 255 because if so could I not just set the prom inputs to the outputs?
I'm thinking a0-a3 could be the low nibble and a4-a7 could be the high nibble.
YES.Just tried it in mame with two bin files to just set the nibbles to 0-255 between them and got the game to boot.
Now to try wiring the addresses and see if that works on the real board.
thanks for the info dude.
Lurch6662018-08-18 13:34:49
Lurch666
21 (100%)
4,519CR
Didn't think that would work.
When I was checking out the connections to tie the address lines to the outputs of the two 256 byte proms I realised I would have no chip enable so figured it just wouldn't work.
Imagine my surprise when I got it to work but only after removing one of the 32 byte proms.
So you can get ladybug to run on a dorodon board with a bit of modification.Unfortunately I don't have any 2732s to replace the graphic roms so I will have to wait till some arrive to see if I need to replace the colour prom.
Lurch666
21 (100%)
4,519CR
Just an update.
Got the 2732 and burned them to ladybug and now have the game fully converted using a couple of gals to replace the colour proms.
Here's what the wiring looks like on the bypass of the protection proms:
