Dragons Lair
Retroruss
95CR
Any DL experts around the Derbyshire area, need some assistance, think I'm close to getting this working just seems to be a communication issue between the Hitech card, player and main pcb?
Getting all the right initialisation beeps and numbers on the score board just don't seem to be playing the disk and no comms lights on the Hitech card?
Very frustrating had this machine some years now and would love to see it working.
G
Guests
Guest
Have a chat with Rich - Dex-Jay. He has DL's coming out of his ears!
Dex-Jay
375CR
What powers the card, the adaptor or did you take 5V from the ROM board?
Does the Hi-Tech card light up with chaser lights when you boot up?
Is the DL booting OK and making 2 beeps when you fire it up with a working display?
More likely than not its a cable issue. The Ribbon cables on the board are delicate and should only go in the 1 way. Also make sure the Hi-Tech to player is a Null Modem cable, a mistake easily made, I've done it! (derp)
If you're using a Sony Lasermax make sure the board rate on the back is correct too.
A pic will help if you're unsure of anything....
Retroruss
95CR
Hitech card powered by adapter pluged into back of laser player.
Yep boots up "chase sequence" and then flashes led 2 for PR setting
Yep get the two boot beeps then a third dull beep, display seems to display the dull red background in a frozen state.
Will get some pics up tomorrow.
Dex-Jay
375CR
Jumper J9 is off, hence LED 2 flashing so it's in PR-7820 mode, not LD-V1000 mode. Have you tried it with the jumper installed? The original laserdisc player settings are set by the dip switches on the DL PCB. Download the DIP settings and make sure everything is alright there too.
I would say the board and card look fine, so if the jumper doesn't cure it then check the board rate dip switches on the back of the player, Sony Lasermax? If still no joy it is either the cable to the PCB in backwards? Or failing that the Coms cable may not be the Null Modem cable.
I really think it is something really minor myself.
Richster
Dex-Jay
375CR
Just watched the rest of the video and the cable in the DL PCB looks to be in the right way. Which Lasermax is that? 4 Dips on the back of it are there? Check 'em!
Retroruss
95CR
Tried it with the jumper in some time ago and it still flashes led 2, not checked the dip switches on the back of the laser player for some time so will check them tomorrow night, from memory I think it's a lasermax 2000.
