Dream Land (BB clone)
Kingpin
113CR
Have this bootleg of Bubble Bobble and it's Dream Land or possibly Super Dream Land (I think).
I think one of the ROMs are blank ("1-D" (27256)).
Anybody who has this file or preferably the whole set dumped?
Also, is it possible to "Redux" this type of board?
Thanks!
Kingpin2022-11-06 17:53:22
mysticmonk
1,051CR
I found it and started it up.
There isn't much mention of this version of bubble bobble bootleg so I thought I'd take a picture while I'm at it. Unfortunately it isn't the same pcb type as yours, and double unfortunate I don't have any rom reading/burning tools. Sorry I'm not much help!
qjuk
51 (98%)
2,079CR
I was under the impression that as long as your bootleg board has a Z80 processor (which yours does) then it can be Redux’ed. I think it might be a case of simply replacing roms 1-B, 1-C and 1-D on yours with the Redux roms for it to work.
qjuk2022-11-06 22:55:01
Kingpin
113CR
Got hold of that ROM set (I think) but the files do not match up to the locations or markings on my board. Maybe I need to download all variants and study if any match.
Kingpin
113CR
qjuk; I see, sounds simple for sure! Do you happen to know if there is a "official" site for the Redux ROMs/project?
Thanks!
Kingpin2022-11-07 08:18:55
qjuk
51 (98%)
2,079CR
I’m not currently at home at the moment so I can’t check my notes, but from memory I’m sure the Redux roms are also in the Lost Cave file zip which you can get direct from lostcave.wordpress.com.
The files you need are BB3, BB4 and BB5. It looks like on your board eprom 1-B = BB5, 1-C = BB4 and 1-D = BB3.
favouredson
Super Star
1,260CR
According to the MAME driver, the file named DL_3.U69 should match your 1-D ROM.
(Unless there are other versions not in MAME...)
Kingpin
113CR
Redux ROMs installed and it boots and it seems that the code is working, so that's great! :)
I do have graphics problems and weird steering/controls though.
In test mode I get RAM OK.
Controls:
1P RIGHT = 1P RIGHT
1P LEFT = 2P LEFT
2P RIGHT = 2P RIGHT
2P LEFT = 1P LEFT
1P AWA = 2P AWA
1P JUMP = 2P JUMP
1P SELECT = 2P SELECT
2P SELECT = 1P SELECT
Of course I could make a 56pin converter to sort the controls as they seems to be mixed up between the players. Since voltages, colors, audio etc. is working I must assume that the board is JAMMA?
Main screen:
Sprites looks weird:
qjuk
51 (98%)
2,079CR
Edit: I've just noticed the title screen is showing the text from the Lost Cave roms, so I'm guessing the BB3, BB4 and BB5 roms in that zip file are not the Redux roms after-all (I thought they may have been). This would explain the messed up graphics and possibly the wrong platform locations in the game.
Not all the bootleg boards are Jamma, it could be using a similar pinout and the controls simply have a different layout. Try getting and burning the Redux roms first and see it that has affected the controls. Failing that, I would make up a new Jamma adapter and wire the controls to the right pins on the adapter itself.
qjuk2022-11-08 22:23:51
qjuk
51 (98%)
2,079CR
Edit: I originally found the Redux roms from a thread on the Arcade Otaku forum, drop me a PM if you need help finding them.qjuk2022-11-08 22:34:26
Kingpin
113CR
You were right! :) The ROMs wasn't correct and so after finding a random ROM set on the net I re-programmed the EPROMs and got the correct main screen (sprite problems remain though but probably some other fault as I actually found a thread on KLOV with someone having the exact same issues (no solution though) https://forums.arcade-museum.com/threads/bubble-bobble-bootleg-pcb-repair-help.277323 ).
qjuk
51 (98%)
2,079CR
With regards to the block graphic sprites, my first job would be to dump and verify the 1-F and 1-G graphic roms to see if they are both good if you’ve not done that already.
Also, reseat any other socketed IC’s to if it solves the issue.
I know you previously said that you had a Ram OK in test, but I’m sceptical if all the ram is actually checked, especially since it’s a bootleg. I still wouldn’t rule out a bad ram somewhere.
I also noticed on the photo of your pcb that a 74LS161 counter at the edge of the board is at quite an angle and barely looks like it been soldered in properly. Just check to make sure all the pins are making contact.
Kingpin
113CR
Yep, will check those ROMs but I think they checked out with ROMIdent so maybe a question of if there was other ROMs (not socketed) maybe or a solder blob somewhere perhaps. I've inspected the few signals that looked suspicious and the chips are seated properly and the sockets are ok. But I'll double-check for sure, heck, I almost have a (working) Redux BB!
