Driving Cab - what do these things do then?
ataridude74
264CR
I've finally got my Electrocoin Driver fitted with a restored monitor, running WEC Le Mans.
Next stage of the restore is to restore the control panel, driving wheel and pedal.
So, does anybody know in the pictures below -
[list type=decimal][*]What's that thing with the spring, to the right of the driving wheel? It is being fed from a separate 24v transformer.
[*]What does that button do, to the right of the picture with four wires? They appear to go into the JAMMA loom and on to the PCB.[/list type=decimal]
I've not poked or traced back around too much yet as I've been focussing on the monitor.
The game works fine without them, as I've been playing it today. Great game, very similar in feel to Out Run, and just as hard.
gunblade
9,123CR
thats a solenoid
and it looks like you have a wire on the wrong tab on the switch,the switch itself should have two wires-ground and switch line,the other two wires are for the bulb
ataridude74
264CR
Thanks, makes sense, obvious really
. The green/red and green/black go into the PCB, I presume they'll be the switch wires. Could be a brake, the cab doesn't have one but MAME does (would be a bit awkward to activate though). Leaves the other two for the bulb.
What does the solenoid actually do with the 24 volts?
